install path for libcpu
Hill, Jeff johill at lanl.gov
Tue Oct 2 20:40:49 UTC 2012
> Normally the BSP specifically lists which components
> from libcpu it wants. Those get included in the librtemsbsp.a.
> libcpu objects p--- are not directly installed. The .h files are.
I am still confused; from my perspective it appears that some
of the RTEMS applications, for example netdemo, appear to
explicitly reference librtemscpu.a?
Making all in netdemo
make[1]: Entering directory `/home/hill/nios2-rtems/rtems/rtems-git/network-demos/netdemo'
make[1]: *** No rule to make target
`/home/hill/install/rtems-4.11-/nios2-rtems/altera-sys-config/lib/librtemscpu.a',
 needed by `o-optimize/netdemo.exe'.  Stop.
Thanks for your assistance,
Jeff
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: Tuesday, October 02, 2012 8:56 AM
> To: Hill, Jeff
> Cc: rtems-users at rtems.org
> Subject: Re: install path for libcpu
> On 10/02/2012 09:38 AM, Hill, Jeff wrote:
> > Hello,
> > Maybe someone will have a quick answer for an RTEMS build system mystery
> > that I currently don't understand. I have had to make this change in
> > c/src/make/compilers/gcc-target-default.cfg but I don't understand
> > why others do not experience the same issue?
> > After:
> > LINK_FILES =\
> >      $(CONSTRUCTOR) \
> >      $(OBJS) \
> >      $(PROJECT_RELEASE)/lib/librtemsbsp$(LIBSUFFIX_VA) \
> >      $(PROJECT_RELEASE)/../lib/librtemscpu$(LIBSUFFIX_VA)
> > Before:
> > LINK_FILES =\
> >      $(CONSTRUCTOR) \
> >      $(OBJS) \
> >      $(PROJECT_RELEASE)/lib/librtemscpu$(LIBSUFFIX_VA)
> > If I don't make this change then application codes like the
> > netdemo will not build with the original RTEMS build system.
> > This is probably self inflicted, and no-doubt has something
> > to do with install path for libcpu. I see this issue in all
> > versions of RTEMS, with the Nios2 BSP.
> Here is a fragment from sparc/erc32/Makefile.am to pick up
> the libcpu components that BSP wants:
> libbsp_a_LIBADD  = \
>      ../../../libcpu/@RTEMS_CPU@/access.rel \
>      ../../../libcpu/@RTEMS_CPU@/cache.rel \
>      ../../../libcpu/@RTEMS_CPU@/reg_win.rel \
>      ../../../libcpu/@RTEMS_CPU@/syscall.rel
> libcpu objects are not directly installed. The .h files are.
> > Thanks,
> > Jeff
> > ______________________________________________________
> > Jeffrey O. Hill           Email        johill at lanl.gov
> > LANL MS H820              Voice        505 665 1831
> > Los Alamos NM 87545 USA   FAX          505 665 5107
> > Message content: Correspondence
> > rtems-users mailing list
> > http://www.rtems.org/mailman/listinfo/rtems-users
> Joel Sherrill, Ph.D.             Director of Research&   Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>      Support Available             (256) 722-9985
