install path for libcpu
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Oct 2 21:18:07 UTC 2012
On 10/2/2012 4:09 PM, Hill, Jeff wrote:
>> Did you do a make install after you built RTEMS?
>> Did you set RTEMS_MAKEFILE_PATH to reflect the ${prefix}/${target}/${BSP}?
> Yes, my build script does perform both of the above actions,
> each time that it runs.
Something is subtly wrong. You shouldn't have to edit
gcc-target-default.cfg and I think that's where the dependency is
coming from.
librtemscpu.a is normally picked up by adding -qrtems to the gcc
command line. This dependency is built into gcc if the target is
built to include gcc/config/rtems.h. This is from gcc/config.gcc
for the mips target.
mips*-*-rtems*)
tm_file="elfos.h newlib-stdint.h ${tm_file} mips/elf.h
mips/rtems.h rtems.h"
tmake_file="mips/t-elf t-rtems mips/t-rtems"
Notice that tm_file references rtems.h which corresponds to
gcc/config/rtems.h
and that file has this:
#undef LIB_SPEC
#define LIB_SPEC "%{!qrtems: " STD_LIB_SPEC "} " \
"%{!nostdlib: %{qrtems: --start-group \
-lrtemsbsp -lrtemscpu \
-lc -lgcc --end-group %{!qnolinkcmds: -T linkcmds%s}}}"
Which is how the -lrtemscpu is picked up.
If librtemscpu.a is installed properly in
${prefix}/${target}/${BSP}/lib, then
the gcc built-in library specification should let you find it.
Time to check what gcc is doing.
>> -----Original Message-----
>> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
>> Sent: Tuesday, October 02, 2012 3:03 PM
>> To: Hill, Jeff
>> Cc: rtems-users at rtems.org
>> Subject: Re: install path for libcpu
>> On 10/2/2012 3:40 PM, Hill, Jeff wrote:
>>>> Normally the BSP specifically lists which components
>>>> from libcpu it wants. Those get included in the librtemsbsp.a.
>>>> libcpu objects p--- are not directly installed. The .h files are.
>>> I am still confused; from my perspective it appears that some
>>> of the RTEMS applications, for example netdemo, appear to
>>> explicitly reference librtemscpu.a?
>>> Making all in netdemo
>>> make[1]: Entering directory `/home/hill/nios2-rtems/rtems/rtems-
>> git/network-demos/netdemo'
>>> make[1]: *** No rule to make target
>>> `/home/hill/install/rtems-4.11-/nios2-rtems/altera-sys-
>> config/lib/librtemscpu.a',
>>> needed by `o-optimize/netdemo.exe'. Stop.
>> Hold on... librtemscpu.a is NOT libcpu. It is cpukit.
>> --joel
>>> Thanks for your assistance,
>>> Jeff
>>>> Sent: Tuesday, October 02, 2012 8:56 AM
>>>> To: Hill, Jeff
>>>> On 10/02/2012 09:38 AM, Hill, Jeff wrote:
>>>>> Hello,
>>>>> Maybe someone will have a quick answer for an RTEMS build system
>> mystery
>>>>> that I currently don't understand. I have had to make this change in
>>>>> c/src/make/compilers/gcc-target-default.cfg but I don't understand
>>>>> why others do not experience the same issue?
>>>>> After:
>>>>> LINK_FILES =\
>>>>> $(CONSTRUCTOR) \
>>>>> $(OBJS) \
>>>>> $(PROJECT_RELEASE)/lib/librtemsbsp$(LIBSUFFIX_VA) \
>>>>> $(PROJECT_RELEASE)/../lib/librtemscpu$(LIBSUFFIX_VA)
>>>>> Before:
>>>>> LINK_FILES =\
>>>>> $(CONSTRUCTOR) \
>>>>> $(OBJS) \
>>>>> $(PROJECT_RELEASE)/lib/librtemscpu$(LIBSUFFIX_VA)
>>>>> If I don't make this change then application codes like the
>>>>> netdemo will not build with the original RTEMS build system.
>>>>> This is probably self inflicted, and no-doubt has something
>>>>> to do with install path for libcpu. I see this issue in all
>>>>> versions of RTEMS, with the Nios2 BSP.
>>>> Here is a fragment from sparc/erc32/Makefile.am to pick up
>>>> the libcpu components that BSP wants:
>>>> libbsp_a_LIBADD = \
>>>> ../../../libcpu/@RTEMS_CPU@/access.rel \
>>>> ../../../libcpu/@RTEMS_CPU@/cache.rel \
>>>> ../../../libcpu/@RTEMS_CPU@/reg_win.rel \
>>>> ../../../libcpu/@RTEMS_CPU@/syscall.rel
>>>> libcpu objects are not directly installed. The .h files are.
>>>>> Thanks,
>>>>> Jeff
>>>>> ______________________________________________________
>>>>> Jeffrey O. Hill Email johill at lanl.gov
>>>>> LANL MS H820 Voice 505 665 1831
>>>>> Los Alamos NM 87545 USA FAX 505 665 5107
>>>>> Message content: Correspondence
>>>>> rtems-users mailing list
>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>>> Joel Sherrill, Ph.D. Director of Research& Development
>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>> Support Available (256) 722-9985
