install path for libcpu
Tue Oct 2 22:08:37 UTC 2012
On 10/2/2012 4:57 PM, Hill, Jeff wrote:
> Thanks for that explanation.
>> If librtemscpu.a is installed properly in
>> ${prefix}/${target}/${BSP}/lib/
> This appears to be the root of the problem.
> I see this file:
> ${prefix}/${target}/lib/librtemcpu.a
> I don't see this file:
> ${prefix}/${target}/${BSP}/lib/librtemcpu.a
> Removing ${prefix}/${target}/lib/librtemcpu.a and then
> rebuilding everything doesn't improve my situation.
> So presumably this issue, installation of librtemcpu.a on the
> wrong path, is caused by some configuration mistake in the
> BSP? I will have a look, but any hints are greatly
> appreciated :-)
How did you configure? The ones I have are from configuring like this:
../rtems/configure --target=<CPU>-rtems4.11 --enable-rtemsbsp=<BSP> \
    --prefix=<prefix>
> Jeff
>> -----Original Message-----
>> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
>> Sent: Tuesday, October 02, 2012 3:18 PM
>> To: Hill, Jeff
>> Cc: rtems-users at rtems.org
>> Subject: Re: install path for libcpu
>> On 10/2/2012 4:09 PM, Hill, Jeff wrote:
>>>> Did you do a make install after you built RTEMS?
>>>> Did you set RTEMS_MAKEFILE_PATH to reflect the
>> ${prefix}/${target}/${BSP}?
>>> Yes, my build script does perform both of the above actions,
>>> each time that it runs.
>> Something is subtly wrong. You shouldn't have to edit
>> gcc-target-default.cfg and I think that's where the dependency is
>> coming from.
>> librtemscpu.a is normally picked up by adding -qrtems to the gcc
>> command line. This dependency is built into gcc if the target is
>> built to include gcc/config/rtems.h. This is from gcc/config.gcc
>> for the mips target.
>> mips*-*-rtems*)
>>           tm_file="elfos.h newlib-stdint.h ${tm_file} mips/elf.h
>> mips/rtems.h rtems.h"
>>           tmake_file="mips/t-elf t-rtems mips/t-rtems"
>> Notice that tm_file references rtems.h which corresponds to
>> gcc/config/rtems.h
>> and that file has this:
>> #undef LIB_SPEC
>> #define LIB_SPEC "%{!qrtems: " STD_LIB_SPEC "} " \
>> "%{!nostdlib: %{qrtems: --start-group \
>>    -lrtemsbsp -lrtemscpu \
>>    -lc -lgcc --end-group %{!qnolinkcmds: -T linkcmds%s}}}"
>> Which is how the -lrtemscpu is picked up.
>> ${prefix}/${target}/${BSP}/lib, then
>> the gcc built-in library specification should let you find it.
>> Time to check what gcc is doing.
>>>> Sent: Tuesday, October 02, 2012 3:03 PM
>>>> To: Hill, Jeff
>>>> On 10/2/2012 3:40 PM, Hill, Jeff wrote:
>>>>>> Normally the BSP specifically lists which components
>>>>>> from libcpu it wants. Those get included in the librtemsbsp.a.
>>>>>> libcpu objects p--- are not directly installed. The .h files are.
>>>>> I am still confused; from my perspective it appears that some
>>>>> of the RTEMS applications, for example netdemo, appear to
>>>>> explicitly reference librtemscpu.a?
>>>>> Making all in netdemo
>>>>> make[1]: Entering directory `/home/hill/nios2-rtems/rtems/rtems-
>>>> git/network-demos/netdemo'
>>>>> make[1]: *** No rule to make target
>>>>> `/home/hill/install/rtems-4.11-/nios2-rtems/altera-sys-
>>>> config/lib/librtemscpu.a',
>>>>>     needed by `o-optimize/netdemo.exe'.  Stop.
>>>> Hold on... librtemscpu.a is NOT libcpu. It is cpukit.
>>>> --joel
>>>>> Thanks for your assistance,
>>>>> Jeff
>>>>>> Sent: Tuesday, October 02, 2012 8:56 AM
>>>>>> To: Hill, Jeff
>>>>>> On 10/02/2012 09:38 AM, Hill, Jeff wrote:
>>>>>>> Hello,
>>>>>>> Maybe someone will have a quick answer for an RTEMS build system
>>>> mystery
>>>>>>> that I currently don't understand. I have had to make this change in
>>>>>>> c/src/make/compilers/gcc-target-default.cfg but I don't understand
>>>>>>> why others do not experience the same issue?
>>>>>>> After:
>>>>>>> LINK_FILES =\
>>>>>>>         $(CONSTRUCTOR) \
>>>>>>>         $(OBJS) \
>>>>>>>         $(PROJECT_RELEASE)/lib/librtemsbsp$(LIBSUFFIX_VA) \
>>>>>>>         $(PROJECT_RELEASE)/../lib/librtemscpu$(LIBSUFFIX_VA)
>>>>>>> Before:
>>>>>>> LINK_FILES =\
>>>>>>>         $(CONSTRUCTOR) \
>>>>>>>         $(OBJS) \
>>>>>>>         $(PROJECT_RELEASE)/lib/librtemscpu$(LIBSUFFIX_VA)
>>>>>>> If I don't make this change then application codes like the
>>>>>>> netdemo will not build with the original RTEMS build system.
>>>>>>> This is probably self inflicted, and no-doubt has something
>>>>>>> to do with install path for libcpu. I see this issue in all
>>>>>>> versions of RTEMS, with the Nios2 BSP.
>>>>>> Here is a fragment from sparc/erc32/Makefile.am to pick up
>>>>>> the libcpu components that BSP wants:
>>>>>> libbsp_a_LIBADD  = \
>>>>>>         ../../../libcpu/@RTEMS_CPU@/access.rel \
>>>>>>         ../../../libcpu/@RTEMS_CPU@/cache.rel \
>>>>>>         ../../../libcpu/@RTEMS_CPU@/reg_win.rel \
>>>>>>         ../../../libcpu/@RTEMS_CPU@/syscall.rel
>>>>>> libcpu objects are not directly installed. The .h files are.
>>>>>>> Thanks,
>>>>>>> Jeff
>>>>>>> ______________________________________________________
>>>>>>> Jeffrey O. Hill           Email        johill at lanl.gov
>>>>>>> LANL MS H820              Voice        505 665 1831
>>>>>>> Los Alamos NM 87545 USA   FAX          505 665 5107
>>>>>>> Message content: Correspondence
>>>>>>> rtems-users mailing list
>>>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>>>>> Joel Sherrill, Ph.D.             Director of Research&   Development
>>>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>>>         Support Available             (256) 722-9985
