sparc-rtems4.11-gcc for C++
Jiri Freyvald jiri.freyvald at gmail.com
Thu Oct 25 14:28:14 UTC 2012
I'd suggest to use existing Makefile (for example from  rtems-example-v2),
specify all cc and c source names in
CSRCS=
and
CXXSRCS=
and "make clean all" will do all the job for you
providing you have set PATH for rtems toolchain and RTEMS_MAKEFILE_PATH
correctly
Regards,
Jiri
On 25/10/12 13:55, Luca Cinquepalmi wrote:
> or shall I use sparc-rtems4.11-g++?
> On 10/25/2012 02:43 PM, Luca Cinquepalmi wrote:
>> Does sparc-rtems4.11-gcc compile C++ source code containing classes,
>> etc...?
>> Thanks
>>     Luca
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
