RTEMS 4.9.5 vs 4.10.2 Network Stack
SAeeD
salpha.2004 at gmail.com
Sun Sep 2 13:39:50 UTC 2012
As I tested the new patch with real board, it is OK with TCP client/server
establishment and is OK with UDP server establishment.
But after a call to "sendto" function (defined in
cpukit/libnetworking/rtems/rtems_syscall.c) in UDP client in order to send
some data to server, that familiar data abort problem with "INSN_LDR"
happens again. Excluding this one, seems that all other network
functionalities are fine.
Thanks Bacon for your new patch. :)
On Sun, Sep 2, 2012 at 4:57 PM, Pierre Ficheux
<pierre.ficheux at openwide.fr>wrote:
> Le 02/09/12 13:06, Bacon Xu a écrit :
> > Hi Pierre & Saeed, I have reviewed my patch of RTEMS 4.10.2. It's
> > indeed that I add ONE (__attribute__((packed))) in patch. It's not
> > enough for arm platform. It must add all of places were mentioned in
> > previous mail with __attribute__((packed)).
> > I found those problems in RTEMS 4.9 for porting ARM at9260. When I add
> > those __attribute__((packed)), the version work properly. So in RTEMS
> > 4.10, I add them too. Because of some specific problems, the patch
> > haven't included those modifications.
> > Attachment is the newest patch that I have test it several times. I
> > haven't real mini2440 board, so I can't ensure some important things,
> > such as s3c2440's pll, and other drivers. It just work smoothly in
> > QEMU.
> I will test it on real board tomorrow.
> Thanks for it :)
> regards
> Pierre FICHEUX -/- CTO OW/OWI, France -\- pierre.ficheux at openwide.fr
> http://ingenierie.openwide.fr
> http://www.ficheux.org
> I would love to change the world, but they won't give me the source code
URL: <http://lists.rtems.org/pipermail/users/attachments/20120902/ed6ac733/attachment.html>
