RTEMS 4.9.5 vs 4.10.2 Network Stack
SAeeD
salpha.2004 at gmail.com
Mon Sep 3 15:25:54 UTC 2012
But the updated network stack is in the latest source tree that is in Git
repository, right? I'm using rtems4.10.2.tar.bz2.
Are there any specific tests that volunteers run on their targets for
assistance? I can test the upgraded stack on both LPC3250 and Mini2440
(maybe). But this requires that I get up to dated with official repository,
right?
On Mon, Sep 3, 2012 at 7:16 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Joel is talking about the upgraded network stack, which is an effort
> he has been closely involved with and is now begging for assistance in
> getting the upgraded stack tested / debugged on targets.
> -Gedare
> On Mon, Sep 3, 2012 at 3:48 AM, SAeeD <salpha.2004 at gmail.com> wrote:
> > You mean RTEMS 4.10.2's TCP/IP stack is not ready for testing on target
> > hardware or Mini2440's port in specific? Although I'm testing it on
> hardware
> > and looks fine till now.
> >> The port is far enough along to get help completing it. Please
> > And what do you mean by your last sentence? I guess it's missed after
> > "Please".
> > On Sun, Sep 2, 2012 at 10:54 PM, Joel Sherrill <
> joel.sherrill at oarcorp.com>
> > wrote:
> >> The new TCP/IP stack port isn't ready for you to actually test on your
> >> target hardware but it should compile fine. If that is enough to check
> if
> >> these structure packing and alignment issues exist in the new code base,
> >> please check.
> >> --joel
> >> >As I tested the new patch with real board, it is OK with TCP
> >> > client/server establishment and is OK with UDP server establishment.
> >> >But after a call to "sendto" function (defined in
> >> > cpukit/libnetworking/rtems/rtems_syscall.c) in UDP client in order to
> send
> >> > some data to server, that familiar data abort problem with "INSN_LDR"
> >> > happens again. Excluding this one, seems that all other network
> >> > functionalities are fine.
> >> >Thanks Bacon for your new patch. :)
> >> >On Sun, Sep 2, 2012 at 4:57 PM, Pierre Ficheux
> >> > <pierre.ficheux at openwide.fr<mailto:pierre.ficheux at openwide.fr>>
> wrote:
> >> >Le 02/09/12 13:06, Bacon Xu a écrit :
> >> >> Hi Pierre & Saeed, I have reviewed my patch of RTEMS 4.10.2. It's
> >> >> indeed that I add ONE (__attribute__((packed))) in patch. It's not
> >> >> enough for arm platform. It must add all of places were mentioned in
> >> >> previous mail with __attribute__((packed)).
> >> >> I found those problems in RTEMS 4.9 for porting ARM at9260. When I
> add
> >> >> those __attribute__((packed)), the version work properly. So in RTEMS
> >> >> 4.10, I add them too. Because of some specific problems, the patch
> >> >> haven't included those modifications.
> >> >> Attachment is the newest patch that I have test it several times. I
> >> >> haven't real mini2440 board, so I can't ensure some important things,
> >> >> such as s3c2440's pll, and other drivers. It just work smoothly in
> >> >> QEMU.
> >> >I will test it on real board tomorrow.
> >> >Thanks for it :)
> >> >regards
> >> >Pierre FICHEUX -/- CTO OW/OWI, France -\-
> >> > http://ingenierie.openwide.fr
> >> > http://www.ficheux.org
> >> >I would love to change the world, but they won't give me the source
> code
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20120903/99d83541/attachment.html>
