sparc-rtems4.11-gdb error
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Sep 4 13:26:24 UTC 2012
On 09/04/2012 07:10 AM, Luca Cinquepalmi wrote:
> Hi Joel,
> the debugger version is 7.4.1 and I built it with rpm.
> My pyhton version is 2.6.
> Shall I build it by myself?
I wasn't suggesting that. Just trying to respond quickly and ask
for enough details to know whether this was an RPM, a locally
built binary, etc.
I am on CentOS 6.3 with these RPMs:
rtems-4.11-sparc-rtems4.11-gdb-7.4.1-1.el6.i386
python-2.6.6-29.el6_2.2.i686
And it works fine. I guess the next question is your host OS
and how you invoked sparc-rtems4.11-gdb.
Ralf builds these so if there is some odd dependency not being
properly met he would know that.
--joel
> Luca
> Il 04/09/2012 13.57, Joel Sherrill ha scritto:
>> What is the version of the debugger?
>> Is this an RPM or did you build it yourself? If you build it, then how did you configure?
>> Luca Cinquepalmi<cinquepalmi at planetek.it> wrote:
>> Hi all,
>> I successfully installed rtems-4.11. I'm able to compile C source
>> file without any problem
>> but when I run rtems debugger (sparc-rtems4.11-gdb) the following
>> messages appears:
>> *'import site' falied; use -v for traceback
>> Traceback (most recent call last)
>> File "<string>", line 1, in ?
>> ImportError: No module named os*
>> so debugger doesnt'work well. I'm not able to solve this problem
>> although I'm still researching
>> any suggestion on the web.
>> Can you help me? Thanks a lot.
>> Luca
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20120904/03725f22/attachment.html>
