sparc-rtems4.11-gdb error
Luca Cinquepalmi
cinquepalmi at planetek.it
Tue Sep 4 13:36:11 UTC 2012
Yes I convert RPM to deb. I'll try your suggestion
Thanks
Il 04/09/2012 15.34, Joel Sherrill ha scritto:
> On 09/04/2012 08:30 AM, Luca Cinquepalmi wrote:
>> I'm on Ubuntu 10.04 LTS with these RPM installed:
>> rtems-4.11-sparc-rtems4.11-gdb_7.4.1-2_i386
>> I didn't install any python RPM... should I?
> Oh! You converted the RPM to deb or extracted the contents.
> That changes things. :)
> Try "ldd /opt/rtems-4.11/bin/sparc-rtems4.11-gdb" and see if all
> the shared library dependencies are met. That's a starting point.
> Hopefully an Ubuntu user will speak up soon. :)
> --joel
>> Luca
>> Il 04/09/2012 15.26, Joel Sherrill ha scritto:
>>> On 09/04/2012 07:10 AM, Luca Cinquepalmi wrote:
>>>> Hi Joel,
>>>> the debugger version is 7.4.1 and I built it with rpm.
>>>> My pyhton version is 2.6.
>>>> Shall I build it by myself?
>>> I wasn't suggesting that. Just trying to respond quickly and ask
>>> for enough details to know whether this was an RPM, a locally
>>> built binary, etc.
>>> I am on CentOS 6.3 with these RPMs:
>>> rtems-4.11-sparc-rtems4.11-gdb-7.4.1-1.el6.i386
>>> python-2.6.6-29.el6_2.2.i686
>>> And it works fine. I guess the next question is your host OS
>>> and how you invoked sparc-rtems4.11-gdb.
>>> Ralf builds these so if there is some odd dependency not being
>>> properly met he would know that.
>>> --joel
>>>> Luca
>>>> Il 04/09/2012 13.57, Joel Sherrill ha scritto:
>>>>> What is the version of the debugger?
>>>>> Is this an RPM or did you build it yourself? If you build it, then how did you configure?
>>>>> Luca Cinquepalmi<cinquepalmi at planetek.it> wrote:
>>>>> Hi all,
>>>>> I successfully installed rtems-4.11. I'm able to compile C source
>>>>> file without any problem
>>>>> but when I run rtems debugger (sparc-rtems4.11-gdb) the following
>>>>> messages appears:
>>>>> *'import site' falied; use -v for traceback
>>>>> Traceback (most recent call last)
>>>>> File "<string>", line 1, in ?
>>>>> ImportError: No module named os*
>>>>> so debugger doesnt'work well. I'm not able to solve this problem
>>>>> although I'm still researching
>>>>> any suggestion on the web.
>>>>> Can you help me? Thanks a lot.
>>>>> Luca
>>> Joel Sherrill, Ph.D. Director of Research& Development
>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20120904/6631f0d1/attachment.html>
