[solved] sparc-rtems4.11-gdb error + gdb question
Luca Cinquepalmi cinquepalmi at planetek.it
Thu Sep 6 07:52:32 UTC 2012
I solved my problem. Actually the problem was that I used rtems-gdb RPM.
I tryed to build it by myself and now I don't have that kind of error.
I have now another question.
What kind of option shall I add in my makefile to compile rtems source
file in debug mode?
Only -g in compyling options and links? Shall I add some command in C
source file?
Compiled in release mode my software works fine...
Thanks a lot
     Luca
Il 04/09/2012 15.59, Luca Cinquepalmi ha scritto:
> What does this message mean?
> 'import site' failed; use -v for traceback
> Traceback (most recent call last):
>   File "/usr/lib/command-not-found", line 10, in <module>
>     import CommandNotFound
> ImportError: No module named CommandNotFound
> this is the result of "system" command.
> Do you have a skype contact?
> Il 04/09/2012 15.53, Joel Sherrill ha scritto:
>> system sparc-rtems4.11-gdb
