RTEMS 4.9.5 vs 4.10.2 Network Stack
SAeeD
salpha.2004 at gmail.com
Sat Sep 8 14:27:43 UTC 2012
> Is this a private BSP? I don't find it in the RTEMS sources.
The BSP is not available in the RTEMS source because as Joel mentioned in a
conversation with topic "Why there is no BSP for Mini2440..." in
rtems-developers, "Bacon Xu just didn't do the tiny bit of work required to
submit it."
But the patch is publicly available at blog.csdn.net. I dunno the exact
post which contains the newest version of patch.
On Sat, Sep 8, 2012 at 10:42 AM, Sebastian Huber <
> On 31/08/12 12:52, SAeeD wrote:
>> As an extension to Bacon's email, I must mention that the following change
>> is also necessary for the network part of RTEMS to run properly on
>> Mini2440. In the file c/src/lib/libbsp/arm/mini2440/**network/network.c,
>> the
>> following modification must happen:
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120908/947cebb3/attachment.html>
