Ref: Building RTEMS for sparc/sis fails with "error: no acceptable cc found in $PATH"
Andrei Dimitrief-Jianu
andrei.dimitrief.jianu at gmail.com
Mon Sep 17 17:59:58 UTC 2012
Hello,
I am trying to build RTEMS 4.10.2 for sparc/sis.
The build fails with:
configure: WARNING: using cross tools not prefixed with host triplet
configure: error: no acceptable cc found in $PATH
The CL that I use is:
./../rtems-4.10.2/configure --target=sparc-rtems4.10 --enable-rtemsbsp=sis
make all
make install
Not sure if this helps, but the build works for arm/csb336 and arm/csb337
on the same host machine.
Thanks.
URL: <http://lists.rtems.org/pipermail/users/attachments/20120917/6a174a23/attachment.html>
