Ref: Building RTEMS for sparc/sis fails with "error: no acceptable cc found in $PATH"
Mon Sep 17 18:36:12 UTC 2012
You need to have a sparc-rtems4.10 toolset installed. The other BSPs you mentioned were ARM.
__joel
Andrei Dimitrief-Jianu <andrei.dimitrief.jianu at gmail.com> wrote:
>Hello,
>I am trying to build RTEMS 4.10.2 for sparc/sis.
>The build fails with:
>configure: WARNING: using cross tools not prefixed with host triplet
>configure: error: no acceptable cc found in $PATH
>The CL that I use is:
>./../rtems-4.10.2/configure --target=sparc-rtems4.10 --enable-rtemsbsp=sis
>make all
>make install
>Not sure if this helps, but the build works for arm/csb336 and arm/csb337 on the same host machine.
>Thanks.
