Fwd: Developing under MacOS
Binkowski, Cassio
cassioiks at gmail.com
Tue Sep 18 10:34:49 UTC 2012
Hi Everyone
I'm trying to build the RTEMS tools from source but it does not seem to go
through the GCC Download and Build, for every architecture I have tried.
When the tool* *is running for *rtems-4.11-powerpc-rtems4.11-gcc-4.7.1-7/doit
*I get the following error over and over:
*/Users/cassiobinkowski/workspace/rtems/build/BUILD/rtems-4.11-powerpc-rtems4.11-gcc-4.7.1-7/doit:
line 41: cd: gcc-4.7.1: No such file or directory*
I don't know what I'm doing wrong. I even tried downloading the 4.10 tools.
I'm running the following lines inside my *$RTEMS/build* folder:
*export RTEMS=$HOME/workspace/rtems*
*SB=$RTEMS/specbuilder*
*target=$1*
*${SB}/sb-setup . --rtems=$RTEMS/rtems-crossrpms*
*${SB}/sb-crossgcc --url
http://www.rtems.org/ftp/pub/rtems/SOURCES/4.11--prefix=$RTEMS/rtems-crossrpms/rtems4.11
--log l.txt $target
Am I doing something wrong?
Best regards
Cassio
On Fri, Jul 27, 2012 at 6:45 PM, Chris Johns <chrisj at rtems.org> wrote:
> Hi,
> Please follow the steps in the script I attached.
> 1. Clone the rtems-crossprpms.git repo.
> $ git clone git://git.rtems.org/rtems-**crossrpms.git<http://git.rtems.org/rtems-crossrpms.git>
> 2. Run the sb-setup script:
> $ sb-setup . --rtems=<path to the crossrpms clone>
> 3. Run the crossgcc script:
> $ sb-crossgcc \
> --url http://www.rtems.org/ftp/pub/**rtems/SOURCES/4.11<http://www.rtems.org/ftp/pub/rtems/SOURCES/4.11>\
> --prefix=/rtems/4.11 --log l.txt
> After this you will have a tar files in the TAR directory.
> Again please review the sb-build.sh script I attached to the previous
> email.
> Chris
> On 28/07/12 7:39 AM, Binkowski, Cassio wrote:
>> Hi Chris
>> Thank you very much for the scripts. It will sure help a lot.
>> So, please confirm whether I got it right or not:
>> 1) We need to clone the git repository, with source codes and the spec
>> files;
>> 2) We need to build the source codes using the spec files using the
>> script you provided;
>> 3) After step 2, we have TARs, that need will be extracted by the
>> install script.
>> Is this right?
>> But, one more question: what about gcc, autoconf and automake?
>> Best regards
>> Cassio
>> On Mon, Jul 23, 2012 at 8:13 PM, Chris Johns <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>> On 24/07/12 8:10 AM, Binkowski, Cassio wrote:
>> I would like a copy very much. It would be highly appreciated.
>> Follow the details in the link provided. You can find the
>> specbuilder source detailed in the following post I made:
>> http://www.rtems.org/__**pipermail/rtems-users/2012-__**
>> July/010264.html<http://www.rtems.org/__pipermail/rtems-users/2012-__July/010264.html>
>> <http://www.rtems.org/**pipermail/rtems-users/2012-**July/010264.html<http://www.rtems.org/pipermail/rtems-users/2012-July/010264.html>
>> I have attached a script I use.
>> Also, it is not very clear to me these things of building the
>> tools from
>> source and how it would work in MacOS just like it does in Linux.
>> The source used builds on a number of platforms including MacOS. The
>> task is to get that source to build a set of RTEMS tools that match
>> the release.
>> Would you mind giving me a brief overview?
>> Ralf maintains the tools by creating RPM spec files. You find these
>> in the rtems-crossrpms.git repo. A spec file is a detailed script of
>> the steps needed to build a tool chain. If rpmbuild was available on
>> every computer we could all use rpmbuild how-ever rpmbuild is
>> limited to a few Linux distributions. This leave us with a couple of
>> alternatives. Create a separate and parallel means to maintain tools
>> building on "other" hosts from source or write a tool that can use
>> the spec file as a source of steps. About 2 or 3 years ago I decided
>> on the spec file path because it is a write once rather than needing
>> to track all of Ralf changes. It has proved to be very useful.
>> Take a look at the sb-build.sh script. It runs a set-up phase that
>> copies in the spec files from the rtems-crossrpms.git clone you need
>> to have. It then build the tools into tar files. There is an
>> rt-install.sh script that unpacks the tools into the install path.
>> When Ralf releases new tools you get pull the changes into your git
>> repo and rebuild.
>> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20120918/22195343/attachment.html>
