testing multitasking rtems
Luca Cinquepalmi
cinquepalmi at planetek.it
Wed Sep 19 14:16:13 UTC 2012
How can I run Two tasks in the same time? Evey task ends with
delete_task so the next task starts
when the previous is finished. How can I make a second task running when
task one is still running?
Example:
rtems_task Init(rtems_task_argument ignored)
rtems_task_start(task_id1...)
rtems_task_start(task_id2...)
I want that task 2 starts while task1 is still running? How can I do this?
Thank you
Luca
Il 18/09/2012 13.12, Joel Sherrill ha scritto:
> On 09/18/2012 06:07 AM, Luca Cinquepalmi wrote:
>> Hi all,
>> is there on line or in rtems documentaion any exmaple (c source code) of
>> how testing multitasking?
> Nearly every test is multitasking. All are if you consider there is
> at least an application task/thread and an idle task.
> The most basic tests for a BSP are hello and ticker. Ticker has
> 3 user tasks which run at different intervals.
>> I'm not able to find any suggestion. Thank you
>> Luca
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20120919/90a533d0/attachment.html>
