RES: testing multitasking rtems
Luca Cinquepalmi
cinquepalmi at planetek.it
Wed Sep 19 16:24:09 UTC 2012
Wendell, thank you for your answer... I try to explain better:
- task1 makes a led blinking (in a while cycle)
- task2 print a simple "hello world"
I want "hello world" to be printed while led is blinking. How can I
share CPU with these two tasks?
Shall I delete task at the end? Shall I define a semaphore?
I tried to modify task priority but it has no effects...
Even if led blinking (task 1) start, task 2 doesn't...
Hope now it's clearer...
Luca
Il 19/09/2012 17.18, Wendell Pereira da Silva ha scritto:
> Luca,
> Unless you have two CPUs (or a dual core CPU) and SMP support for your
> BSP, it's impossible to get two tasks running at the same time (if I
> understood what you mean "... a second task running when one is still
> running).
> In most cases, on single core (or single processor) BSP's tasks share
> the same CPU being droved by any scheduling policy implemented in the
> RTOS.
> If you want your tasks sharing the CPU, please, check the tasks
> priority, attributes and execution mode.
> Probably task one has higher priority than task two, and task one
> never blocks.
> A good reference is the RTEMS Users Guide
> <http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.10.2/share/rtems/pdf/c_user.pdf>,
> topic 5.2.
> Hope it helps.
> --Wendell
> *De:*rtems-users-bounces at rtems.org
> [mailto:rtems-users-bounces at rtems.org] *Em nome de *Luca Cinquepalmi
> *Enviada em:* quarta-feira, 19 de setembro de 2012 11:16
> *Para:* Joel Sherrill
> *Cc:* rtems-users at rtems.org
> *Assunto:* Re: testing multitasking rtems
> How can I run Two tasks in the same time? Evey task ends with
> delete_task so the next task starts
> when the previous is finished. How can I make a second task running
> when task one is still running?
> Example:
> rtems_task Init(rtems_task_argument ignored)
> rtems_task_start(task_id1...)
> rtems_task_start(task_id2...)
> I want that task 2 starts while task1 is still running? How can I do this?
> Thank you
> Luca
> Il 18/09/2012 13.12, Joel Sherrill ha scritto:
> On 09/18/2012 06:07 AM, Luca Cinquepalmi wrote:
> Hi all,
> is there on line or in rtems documentaion any exmaple (c source
> code) of
> how testing multitasking?
> Nearly every test is multitasking. All are if you consider there is
> at least an application task/thread and an idle task.
> The most basic tests for a BSP are hello and ticker. Ticker has
> 3 user tasks which run at different intervals.
> I'm not able to find any suggestion. Thank you
> Luca
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120919/433b4d8e/attachment.html>
