RTEMS 4.10.2 and openSSL 1.0.0.d
    Sebastian Huber
    Mon Sep 24 08:29:45 UTC 2012
Hello,
you can use the stack checker (confdefs.h define
CONFIGURE_STACK_CHECKER_ENABLED) to get an estimate of the stack size
requirements of your tasks.  Just make the stacks big enough for a start.  You
can use rtems_stack_checker_report_usage_with_plugin() to print out the current
stack usage of all threads.
On 09/12/2012 12:12 PM, VIRAL SHAH wrote:
> Hi All,
> I would like to figure out what could be the maximum stack needed when I use
> PPP along with the openssl library. Any information on this will be very useful.
> Thanks & Best Regards,
> Viral Shah.
> rtems-users mailing list
> rtems-users at rtems.org
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
