Some confusion about the "First Deadline Rule"
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Sep 5 14:44:30 UTC 2012
On 09/05/2012 09:38 AM, Tom Smith wrote:
> hi joel
> Glad to receive an email from you. To me, you are the God of RTEMS
> world. :)
:) <blush>
> For me, it is totally ok to use the discussion as a supplement to that
> section in manual.
> I think gedare's attitude is more important, because gedare provided
> the deep insight on this topic.
> For now, I think I am just new to RTEMS and not sufficient to write
> some usefull material. But I am studying
> an OS course from Internet, I will come up with a new version of that
> section when I finished the scheduling chapters.
This is a new section in the manual and a tough subject to discuss.
I really believe that each new user should feel free to ask questions.
Your first reading of the documentation will see things that RTEMS
developers and more experienced users simply read around. After
a certain point, we all see what we expect to see.
Please make suggestions and corrections. RTEMS has a very wide
user base with lots of differences in native language and backgrounds.
If the manual doesn't make something clear to you, then this is just
your first opportunity to contribute. :)
Plus explaining how to select the appropriate thread scheduling
algorithm for your application is just hard.
--joel
> Best regards
> Tom
> 2012/9/5 Joel Sherrill <joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>>
> Can any of this discussion be used as material to enhance
> the section in the manual? This stuff is very hard to explain.
> Tom .. any suggestions? Just emailing us a new version of
> the section would help. It is just a few paragraphs.
> On 09/05/2012 04:37 AM, Tom Smith wrote:
>> hi Gedare
>> Thank you very much for the quick reply.
>> The relationship between "processor utilization rule" and "First
>> Deadline Rule" you stated is clear and wonderfull.
>> I think I got your key point. But I still need to read more to
>> fully understand RMS.
>> Anyhow, thank you very much
>> tom
>> 2012/9/3 Gedare Bloom <gedare at rtems.org <mailto:gedare at rtems.org>>
>> On Mon, Sep 3, 2012 at 8:27 AM, Tom Smith
>> <venture.g at gmail.com <mailto:venture.g at gmail.com>> wrote:
>> > Hi everyone,
>> > I am studying Chapter 19 "Rate Monotonic Manager" of
>> c_user.pdf, and I get
>> > some questions
>> > In c_user.pdf, it says
>> > "For a given set of independent periodic tasks, if each
>> task meets its first
>> > deadline when all
>> > tasks are started at the same time, then the deadlines will
>> always be met
>> > for any combination
>> > of start times."
>> > my question is that:
>> > 1. If a set of independent periodic tasks do not meet the
>> "Processor
>> > Utilization Rule", but they satisfy the "First Deadline
>> Rule", can they be
>> > scheduled using RMS ?
>> Yes; you may like to consult a handbook on real-time systems for
>> detailed explanations, but I'll make an effort here. The
>> processor
>> utilization rule is a sufficient but not necessary test for
>> schedulability; some systems are schedulable that do not
>> satisfy the
>> maximum processor utilization bounds. The "First Deadline
>> Rule" is a
>> way to simplify the analysis of when tasks may start by
>> stating the
>> worst-case scheduling window happens when all tasks start at
>> the same
>> time; releasing all tasks at once ensures that every task has a
>> critical instant at the same time; this rule coincides with the
>> critical instance theorem. When you don't have simultaneous
>> release of
>> tasks you cannot be certain when the critical instance of a
>> given task
>> will occur, in which case you may need to compute the entire
>> hyperperiod; for non-harmonic task sets the hyperperiod could be
>> prohibitively large. (Harmonic periodic tasks are typically
>> quite easy
>> to test for schedulability.)
>> > 2. Is it necessary to start all tasks at the same time in a
>> real
>> > application, or is it just a trick during analysis phase?
>> I suppose that depends how closely you want your analysis to
>> match
>> your application. If you analyze with simultaneous release
>> but do not
>> ensure that during execution then what have you analyzed? You
>> cannot
>> be certain your application will meet its deadlines anymore.
>> In this
>> case you should use a schedulability test that does not require
>> simultaneous release.
>> -Gedare
>> > any review on this point from anyone is welcomed. So feel
>> free to comment.
>> > Best regards,
>> > Tom Smith
>> > _______________________________________________
>> > rtems-users mailing list
>> > rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>> > http://www.rtems.org/mailman/listinfo/rtems-users
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20120905/b4ab2548/attachment-0001.html>
