[solved] sparc-rtems4.11-gdb error + gdb question
Thu Sep 6 08:40:05 UTC 2012
Luca Cinquepalmi wrote:
> I solved my problem. Actually the problem was that I used rtems-gdb RPM.
> I tryed to build it by myself and now I don't have that kind of error.
Well done.
> I have now another question.
> What kind of option shall I add in my makefile to compile rtems source
> file in debug mode?
> Only -g in compyling options and links?
That should be fine.
> Shall I add some command in C source file?
How do you connect your target to gdb ?
