passing parameters to task
Mathew Benson
mathew.benson at gmail.com
Mon Sep 17 10:18:31 UTC 2012
The same way you would with a POSIX pthread create call. Just malloc a struct with your multiple parameters, set your parameters, and pass the reference of your struct to the function. In your task entry point, cast the argument to a pointer to your struct and pull your parameters out.
Sent from my Amiga 1000
On Sep 17, 2012, at 4:35 AM, Luca Cinquepalmi <cinquepalmi at planetek.it> wrote:
> Hi all,
> I would like to know if is it possible to pass more than one argument to a single task...
> At the moment I only use this syntax when I define a task
> rtems_task Test_task(rtems_task_argument unused)
> How can I declare and define a more parameters dependent task?
> Thanks a lot.
> Luca
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20120917/3e9f2370/attachment-0001.html>
