Building Tools From Source
Fri Sep 21 04:49:32 UTC 2012
Ralf Corsepius wrote:
>>> * The symlinks are a way to build these libraries from source while
>>> building GCC. This means static linking and therefore is not
>>> necessarily a good idea.
>> I think for RTEMS having these libraries built with GCC (statically
>> linked or not) has advantages. The reasons statically linking can be
>> considered harmful are well known [1] how-ever having these libraries
>> that are an important part of the compiler controlled as part of the
>> compiler's configuration set goes a long way to simplifying the
>> verification and validation audit. If I was currently responsible for
>> building a critical application I would like to be able to audit and
>> provide to the V&V team the exact configuration used for testing,
>> development and release. For me this means aways building the tools from
>> source.
> Well, that's the common argument proponents of static linkage come up
> with. With my Fedora Packaging Committee hat on, I cannot avoid to call
> this view "short-sighted" and "dangerous".
I agree a distribution would have this view and if I was in your
position with that hat on I would 100% agree.
RTEMS is not a distribution and that 'hat' is not as good a fit. RTEMS
is an operating system and in a lot cases orthogonal to the requirements
the development host has. Making sure I can come back to the application
being developed many many years later and can generate the same
instructions given the same input source code is an overriding requirement.
> Apart from the technical problems static linkage can imply (It's often
> not possible - Does not apply to gmp, mpfr and mpc), experience from
> history tells, in longer terms, static linkage is guaranteed to be hit
> by the downsides of static linkage by different extends.
The key requirement is being able to rebuild the compiler and generate
the same instructions. If the host being used is not able to perform
that task that host is questionable.
> Prominent example from history: The zlib incident ca. 15 years ago.
> Then, zlib was suffering from security senitive bugs, which had gone
> through unnoticed for a long time. Tnanks to the fact everybody used
> statically linked zlibs, then, when these issues were finially noticed,
> fixing this issue was very tedious for OS vendors and product vendors.
I agree this is a good fit for a host and a distribution how-ever the
security of a host does not effect the instructions the compiler creates
given the RTEMS source code.
> In other words, when vendor supplied libraries suffer from bugs, you're
> better off using shared libs.
Except if there is a possible chance the code generated changes then you
have a problem. Going back and getting the old source and building the
compiler a different way because you need those specific dependent parts
exactly the same would also be questionable if the way you build the
compiler changes. Loading the old OS into a VM is a possible solution if
the VM can host that specific version of the host OS.
> I don't know if Apple or a trustworthy 3rd
> party supplies binaries for gmp, mpfr, mpc on MacOS (I would be
> surprised if this does not apply), you're likely better off using these
> libraries and to apply shared linkage and not to use your "homegrown"
> static versions.
I have no idea what Apple provide on MacOS, or what is provided on
FreeBSD (I use both) nor do I need to be concerned.
