Mingw autoconf 2.69 package
Matthew J Fletcher
amimjf at gmail.com
Wed Apr 3 14:15:35 UTC 2013
Hi,
I've been attempting to build git head (4.11) on mingw but i am having a
bit of problem installing the updated autoconf package available here.
ftp://ftp.rtems.org/pub/rtems/mingw64/4.11/i686/rtems-4.11-autoconf/
I am a bit of a mingw newbe do i just extract and copy over the new files ?
I tried this in two steps;
1) overwrite the /opt/rtems-4.11/ 'bin' and 'share' directories with files
from autoconf 2.69
2) because there was a autoconfig (and auto* in /bin) renamed those with _
in front of them.
autoconf --version now gives 2.69, yay !
Alas doing a bootstrap gives.
-------------- snip -------------------
$ ./bootstrap
./c
Can't locate Autom4te/ChannelDefs.pm in @INC (@INC contains:
/opt/rtems-4.11/share/autoconf /usr/lib/perl5/5.8/msys /usr/lib/perl5/5.8
/usr/lib/perl5/site_perl/5.8/
msys /usr/lib/perl5/site_perl/5.8 /usr/lib/perl5/site_perl/5.8
/usr/lib/perl5/vendor_perl/5.8/msys /usr/lib/perl5/vendor_perl/5.8
/usr/lib/perl5/vendor_perl/5.8 .) at /mingw/bin/autoreconf line 39
BEGIN failed--compilation aborted at /mingw/bin/autoreconf line 39.
grep: Makefile.in: No such file or directory
------------------- snip ----------------
So i dont think i've done it right, is there a simple set of instructions i
can follow ?
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130403/e86dca8c/attachment.html>
