build stuck: rtems-4.10.2, arm-elf, nds
Wed Apr 10 13:23:07 UTC 2013
Looks like you found the error. Were you following some bad
instructions somewhere that we should fix?
-Gedare
On Wed, Apr 10, 2013 at 9:09 AM, Matt Wette <mwette at alumni.caltech.edu> wrote:
> Oops.   It works.  Didn't expect that.  I guess I'll rebuild the chain.
> localhost$ ./configure --prefix=/opt/rtool4.10 --target=arm-rtems-4.10checking build system type... x86_64-unknown-linux-gnu
> checking host system type... x86_64-unknown-linux-gnu
> checking target system type... Invalid configuration `arm-rtems-4.10': system `4.10' not recognized
> configure: error: /bin/sh ./config.sub arm-rtems-4.10 failed
> localhost$ ./configure --prefix=/opt/rtool-4.10 --target=arm-rtems4.10
> checking target system type... arm-unknown-rtems4.10
> checking for a BSD-compatible install... /usr/bin/install -c
> checking
> On Apr 10, 2013, at 6:04 AM, Matt Wette wrote:
>> On Apr 9, 2013, at 11:20 PM, Ralf Corsepius wrote:
>>> On 04/10/2013 04:18 AM, Matt Wette wrote:
>>>> I'm looking for hints.
>>>> I built tools, then configure rtems-4.10.2 for --target=arm-elf, then make RTEMS_BSP=nds
>>> Why are you trying this?
>>> * "arm-elf" is not a valid target tuple for RTEMS
>>> * "arm-elf" built-GCC toolchains are addressing an entirely different systems (Usually OS-less, bare-metal targets).
>> Can you be more explicit?   I used "./configure --prefix=/opt/rtool-4.10 --target=arm-elf" for binutils, gcc, newlib, gdb.
>> The config for rtems seemed to find the compiler fine.    Has anyone built the toolchain?
>> I never tried --target=elf-rtems4.10 because I thought this would happen:
>> localhost$ ./configure --prefix=/opt/rtool-4.10 --target=arm-rtems-4.10
>> localhost$
>> Matt
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
