path for patches
Joel Sherrill Joel.Sherrill at OARcorp.com
Wed Apr 10 22:17:08 UTC 2013
I am on Centos 6.4 .. But I think I stuck to 32 bit. Given details we can reproduce it.
The RTEMS source builder fetches, patches, and builds so tends to just work.
--joel
Matt Wette <mwette at alumni.caltech.edu> wrote:
On Apr 10, 2013, at 2:49 PM, Joel Sherrill wrote:
> http://git.rtems.org/rtems-tools.git/
>> 2.  HACK: I had to copy /usr/include/linux/stddef.h to /usr/include and add a "typedef unsigned size_t;" to the end of that file.
> This sounds like an odd host issue. What host and where it did crop up?
> This really doesn't sound like an RTEMS issue. Most of our code is cross. :)
Centos 6.4 (x86_64).
I am embarrassed to say I didn't keep good notes.  This had to do with building gcc-4.4.7 (not rtems).
When I did a search I found others had run into the same problem.   I will see if I can reproduce.   I
probably made a mistake somewhere.  (I ran into the "unrecognized -Qy arg", found "." should not be in my PATH.)
Matt
bluefin$ yum whatprovides /usr/include/stddef.h
No Matches found
bluefin$
rtems-users mailing list
rtems-users at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-users
