path for patches
Matt Wette mwette at alumni.caltech.edu
Wed Apr 10 22:31:33 UTC 2013
I was able to reproduce it.   It is my error: building inside the gcc source tree.  (Old habits die hard I guess.)
On Apr 10, 2013, at 3:17 PM, Joel Sherrill wrote:
> I am on Centos 6.4 .. But I think I stuck to 32 bit. Given details we can reproduce it.
> The RTEMS source builder fetches, patches, and builds so tends to just work.
> --joel
> Matt Wette <mwette at alumni.caltech.edu> wrote:
> On Apr 10, 2013, at 2:49 PM, Joel Sherrill wrote:
>> http://git.rtems.org/rtems-tools.git/
>>> 2.  HACK: I had to copy /usr/include/linux/stddef.h to /usr/include and add a "typedef unsigned size_t;" to the end of that file.
>> This sounds like an odd host issue. What host and where it did crop up?
>> This really doesn't sound like an RTEMS issue. Most of our code is cross. :)
> Centos 6.4 (x86_64).
> I am embarrassed to say I didn't keep good notes.  This had to do with building gcc-4.4.7 (not rtems).
> When I did a search I found others had run into the same problem.   I will see if I can reproduce.   I
> probably made a mistake somewhere.  (I ran into the "unrecognized -Qy arg", found "." should not be in my PATH.)
> Matt
> bluefin$ yum whatprovides /usr/include/stddef.h
> No Matches found
> bluefin$
> rtems-users mailing list
> rtems-users at rtems.org
