Raspberry Pi build
Mathew Benson
mathew.benson at gmail.com
Thu Apr 11 13:30:21 UTC 2013
I also had to build m4 from source.
On Thu, Apr 11, 2013 at 7:22 AM, Mathew Benson <mathew.benson at gmail.com>wrote:
> I started building this last night from Alan's instructions. Maybe I
> missed it in the documentation, but the build process requires glibc-static
> on CentOS. The build fails with a difficult to diagnose error. At least
> difficult to find late at night. I was getting a "compiler cannot build
> executables" error. The RTEMS wiki has something on that, but it pointed
> me in the wrong direction. I had to write a sample .c and compile it
> manually with the same switches to determine which switch was causing the
> failure. Then determine which library is required for the offending
> switch. Once I ran "yum install glibc-static", that step passed.
URL: <http://lists.rtems.org/pipermail/users/attachments/20130411/5a725f98/attachment.html>
