Ticks per timeslice issue
Mohammed Khoory
mkhoory at eiast.ae
Fri Apr 12 08:59:03 UTC 2013
I've got my code and trimmed it down as much as I can so that it only
demonstrates the issue, which still occurs. In this test case, all the init
function does is spawn 10 tasks which enter an infinite loop, then switch to
the shell. The system.h file contains the CONFIGURE_TICKS_PER_TIMESLICE
macro.
Attached is a zip file containing an eclipse project containing the source.
I haven't attached the executable because I didn't want to increase the
filesize.
Thanks,
(I'm working with eclipse currently, so my apologies if it's not very
straightforward to compile)
>-----Original Message-----
>From: rtems-users-bounces at rtems.org [mailto:rtems-users-
>bounces at rtems.org] On Behalf Of Sebastian Huber
>Sent: Friday, April 12, 2013 5:08 PM
>To: rtems-users at rtems.org
>Subject: Re: Ticks per timeslice issue
>Hello Mohammed,
>do you have a self contained test case, that shows this problem?
>Sebastian Huber, embedded brains GmbH
>Address : Dornierstr. 4, D-82178 Puchheim, Germany
>Phone : +49 89 189 47 41-16
>Fax : +49 89 189 47 41-09
>E-Mail : sebastian.huber at embedded-brains.de
>PGP : Public key available on request.
>Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>_______________________________________________
>rtems-users mailing list
>http://www.rtems.org/mailman/listinfo/rtems-users
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20130412/6ba9e783/attachment.bin>
