Paravirtualization project - GSOC 2013
Philipp Eppelt philipp.eppelt at mailbox.tu-dresden.de
Sat Apr 13 16:47:59 UTC 2013
Hi,
I was thinking about the CPU issue mentioned in the last years ARINC 653
project.
How can a BSP be written, that has no corresponding CPU?
To be precise:
	c/src/lib/libbsp/paraVirt/
	without cpukit/score/cpu/paraVirt/
This should ease the usage across different CPUs. So the amount of
platform dependent code is reduced.
But another idea crossed my mind. Why not use a approach similar to the
no_cpu?
This would mean to provide a virtual CPU model with a manual describing
how to fill in the CPU dependent code.
Also, introduce a x86_virt (sparc_virt, sparc64_virt and so on) CPU model.
To prevent clobbering the cpukit/score/cpu/ directory they all go into
cpukit/score/cpu/virtCPU/ and an additional configuration parameter
should specify the cpu used.
So instead of --target=i386-rtems4.11 we use --target=virt-rtems4.11
--enableVirtualCPU=i386. (like --enableBSP=)
And the platform independent stuff goes into cpukit/score/cpu/virtCPU/shared
What do you think? Is this feasible?
Regards,
Philipp
