Debugging basic BSP tasking functionality
Wed Apr 17 12:40:06 UTC 2013
On 04/17/2013 02:27 PM, Matthew J Fletcher wrote:
>  >Here a context switch from the Init to the idle (I guess) thread happens.
>   The >_User_extensions_Thread_switch
>  >() is called before the context switch and the running thread is checked.  So
> a sp of >0x814d299c must be in the range of the Init stack area.
> Yes it is, Init() stack area is 0x814d1a70 -> 0x814d2a74 (4100 bytes). So it
> looks like the stack pointer is not getting adjusted correctly when task
> switching into a new thread ? as the rtems_idle task is using the Init() stack
> pointer.
Now I am a bit confused.  What check goes wrong in
Stack_check_Frame_pointer_in_range() at check.c:69 0x81180f6e
rtems_stack_checker_switch_extension() at check.c:276 0x81180f6e
_User_extensions_Thread_switch() at userextthreadswitch.c:41 0x8118cbaa
_Thread_Dispatch() at threaddispatch.c:128 0x8118bce6
_Thread_Enable_dispatch() at threaddispatch.c:59 0x8118bd5e
rtems_task_delete() at taskdelete.c:94 0x81189750
Init() at startup.c:241 0x81007840
In case the stack pointer is out of range, then I guess that the interrupt
exception processing is broken.  It is hard to know what happens without an
actual target.
>  > nm your-app.exe | grep 'bsp_\(section\|stack\)' | sort
> No matches.
Ok, 4.10 uses the old linker command files.  These symbols are only available
in 4.11.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
