Debugging basic BSP tasking functionality
Fri Apr 19 14:12:05 UTC 2013
Congratulations! That sounds like enough for contributing a BSP if
your work is based on the git master or if you have some time to try
the master.
On Fri, Apr 19, 2013 at 9:50 AM, Matthew J Fletcher <amimjf at gmail.com> wrote:
> All,
> Thanks for all your help, with suggestions and advice i now have both error
> trapping exceptions, interrupts and task switching running without any
> detectable stack corruption.
> Sebastian in particular, if your ever in the UK around Birmingham i owe you
> a beer.
> In case anyone looks at this thread in the future this is how i got it
> working on the NXP LPC2292.
> 1) Make sure you poke the MEMMAP register to move the vector address's from
> 0x0 (if thats flash), the on chip SRAM. If your ARM chip does not support
> this type of extension (its not a core ARM7TDMI feature), then you would
> need to use a trampoline in flash to redirect to another address.
> 2) Your start.s needs to move a pre configured vector_block into this
> address, most BSP's do this.
> 3) Your linkerscript needs to reserve address space at this address, again
> most BSP's do this.
> 4) You need to ensure that you have stacks allocated and assigned for each
> exception type. It looks like the IRQ one needs at least 4k.
> On 19 April 2013 09:54, Sebastian Huber <sebastian.huber at embedded-brains.de>
> wrote:
>> On 04/19/2013 10:44 AM, Matthew J Fletcher wrote:
>>>  >What do you mean with basic interrupt handlers?
>>> Not using the IRQ exception handler at 0x18, but like so.
>>> #define VICVectAddr0    REG32(0xFFFFF100)    /* Vector Address 0 Register
>>> #define VICIntEnable    REG32(0xFFFFF010)    /* Interrupt Enable Register
>>> #define VICIntEnClear    REG32(0xFFFFF014)    /* Interrupt Enable Clear
>>> Register */
>>> #define VICIntSelect    REG32(0xFFFFF00C)    /* Interrupt Select Register
>>> VICIntEnClear = VIC_BIT(VIC_TIMER0);        // Ensure the interrupt is
>>> disabled
>>> VICVectAddr0 = (ULONG)tick_handler;        // Address of the ISR
>>> VICIntSelect &= ~VIC_BIT(VIC_TIMER0);        // Timer0 selected as IRQ
>>> VICIntEnable = VIC_BIT(VIC_TIMER0);        // Timer0 interrupt enabled
>>> VICVectCntl0 = VIC_ENABLE | VIC_TIMER0;
>> This will not work.
>>>  >If you want to keep your exception vectors in the flash, then simply
>>> use
>>> arm_exc_interrupt >(on 4.10) or _ARMV4_Exception_interrupt (on 4.11) as
>>> the
>>> entry point for the interrupt >exception.
>>> Do you mean passing arm_exc_interrupt as the handler into
>>> rtems_interrupt_handler_install()  ? that still gives an unhandled IRQ
>>> exception, probably because there is no handler installed in 0x18.
>> No, the normal sequence is this:
>> 1. Interrupt event
>> 2. CPU calls _ARMV4_Exception_interrupt via exception table
>> 3. This calls bsp_interrupt_dispatch (defined in the BSP)
>> 4. This calls the handler installed via rtems_interrupt_handler_install()
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> regards
> Matthew J Fletcher
