Unaligned problem when porting rtems for arm
Joel Sherrill Joel.Sherrill at OARcorp.com
Wed Apr 24 13:39:14 UTC 2013
The arm gdb bsp is intended to help find the correct options. They could be wrong. When I did the bsp variants, I picked CPU variants that looked to hit various multilibs.
The arm had a lot of CPU models and it is easy to make a mistake. Is this with the bsp for the simulator in gdb?
--joel
Gedare Bloom <gedare at rtems.org> wrote:
Given the newness of this port, I would guess the options are wrong.
On Wed, Apr 24, 2013 at 9:19 AM, Sebastian Huber
> Hello,
> in case GCC uses a half-word load or store where it shouldn't, then you have
> 1. wrong compiler options, or
> 2. a compiler bug.
> rtems-users mailing list
> rtems-users at rtems.org
