Unaligned problem when porting rtems for arm
Wed Apr 24 14:55:36 UTC 2013
Please use the 4.11 tools and git master for new development like this.
On Wed, Apr 24, 2013 at 10:05 AM, Peng Fan <van.freenix at gmail.com> wrote:
> Version: arm-rtems4.10-gcc ---- gcc version 4.4.7 20120313
> is okay.
> 2013/4/24 Peng Fan <van.freenix at gmail.com>
>> Hi,
>> 2013/4/24 Joel Sherrill <Joel.Sherrill at oarcorp.com>
>>> The arm gdb bsp is intended to help find the correct options. They could
>>> be wrong. When I did the bsp variants, I picked CPU variants that looked to
>>> hit various multilibs.
>>> The arm had a lot of CPU models and it is easy to make a mistake. Is this
>>> with the bsp for the simulator in gdb?
>> I am porting RTEMS to a hardware board based on S3C6410, not for the
>> simulator for gdb.
>>> --joel
>>> Gedare Bloom <gedare at rtems.org> wrote:
>>> Given the newness of this port, I would guess the options are wrong.
>>> On Wed, Apr 24, 2013 at 9:19 AM, Sebastian Huber
>>> <sebastian.huber at embedded-brains.de> wrote:
>>> > Hello,
>>> > in case GCC uses a half-word load or store where it shouldn't, then you
>>> > have
>>> > 1. wrong compiler options, or
>>> > 2. a compiler bug.
>>> > Sebastian Huber, embedded brains GmbH
>>> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> > Phone   : +49 89 189 47 41-16
>>> > Fax     : +49 89 189 47 41-09
>>> > E-Mail  : sebastian.huber at embedded-brains.de
>>> > PGP     : Public key available on request.
>>> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> > _______________________________________________
>>> > rtems-users mailing list
>>> > rtems-users at rtems.org
>>> > http://www.rtems.org/mailman/listinfo/rtems-users
