Problem compiling rtems 4.10 on Debian
Joel joel.sherrill at OARcorp.com
Wed Apr 24 15:01:49 UTC 2013
On 4/24/2013 8:02 AM, Gedare Bloom wrote:
> Are `make bootstrap` and `make configure` valid options for RTEMS
> builds? I've never used either one... Are you following some guide?
> The usual process is just:
> mkdir b-rtems
> cd b-rtems
> ../rtems/configure <...>
> make
Do you have sparc-rtems4.10-gcc installed?
Can it link an empty main() {}
--joel
> On Wed, Apr 24, 2013 at 8:54 AM, Nicolás Alvarez <nicoalar.22 at gmail.com> wrote:
>> Hi all, I having problems building rtems 4.10 on a 64bits Debian wheezy. I
>> dont have problems when a do make bootstrap and make configure, but when I
>> try to compile (make compile), I got this:
>> checking whether the C compiler works... no
>> configure: error: in `/opt/rtems-4.10/src/build-drvmgr/sparc-rtems/c/leon2':
>> configure: error: C compiler cannot create executables
>> See `config.log' for more details
>> make[3]: *** [leon2] Error 1
>> make[3]: Leaving directory `/opt/rtems-4.10/src/build-drvmgr/sparc-rtems/c'
>> make[2]: *** [all-recursive] Error 1
>> make[2]: Leaving directory `/opt/rtems-4.10/src/build-drvmgr/sparc-rtems/c'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory `/opt/rtems-4.10/src/build-drvmgr'
>> Any one knows why this could be?
>> Thank!
>> Ing. N. Alvarez
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
Joel Sherrill, Ph.D.              Director of Research & Development
joel.sherrill at OARcorp.com         On-Line Applications Research
Ask me about RTEMS: a free RTOS   Huntsville AL 35805
Support Available                 (256) 722-9985
