Unaligned problem when porting rtems for arm
Peng Fan
van.freenix at gmail.com
Thu Apr 25 06:34:36 UTC 2013
Hi,
Thanks for all your advice.
I use arm-rtemseabi4.11-gdb to debug the code. The test bsp is arm1136jfs
I add such test code in hello sample:
char *tmp = "/";
char dest[10];
dest[0] = 'a';
dest[1] = '\0';
printf("dest %x, len %x\n", dest, strlen(dest));
strncat(dest, tmp, 10);
printf outputs : dest 1b6bc, len 1
gcc optimize strncat function.
The step debug log is listed below:
Breakpoint 2, 0x00000814 in Init (ignored=<optimized out>)
at
../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c:32
32 strncat(dest, tmp, 10);
1: x/i $pc
=> 0x814 <Init+68>: strh r3, [r4, r0] *//r4+r0 is unaligned.*
(gdb) i r r0
*r0 0x1 1*
(gdb) i r r4
*r4 0x1b6bc 112316*
(gdb) i r r3
r3 0x2f 47
(gdb) c *//It is ok*
Continuing.
*** HELLO WORLD TEST ***
Hello World
*** END OF HELLO WORLD TEST ***
[Inferior 1 (process 42000) exited with code 05]
No error msg with "strh r3, [r4, r0]", when arm-rtemseabi4.11-run
hello.exe. I do not know why.
Regards,
Peng.
2013/4/24 Sebastian Huber <sebastian.huber at embedded-brains.de>
> On 04/24/2013 05:30 PM, Joel Sherrill wrote:
>> On 4/24/2013 10:26 AM, Sebastian Huber wrote:
>>> On 04/24/2013 04:05 PM, Peng Fan wrote:
>>>> Version: arm-rtems4.10-gcc ---- gcc version 4.4.7 20120313
>>>> is okay.
>>>> This version does not use the EABI version 5 and is horribly out of
>>> date.
>>> If you don't want unaligned load/store instructions, then use the
>>> -mno-unaligned-access GCC option.
>>> Asking out of ignorance, is there a chance newilb will include some?
> This is possible, yes. GCC assumes cores for the ARMv6 and later can cope
> with unaligned access.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20130425/a7403080/attachment.html>
