No GDB file
Binkowski, Cassio cassioiks at gmail.com
Sun Apr 28 02:09:53 UTC 2013
Ok. Installed it.
When I try to run my .exe (and an example one) it returns the following:
*rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC cannot
initialize exceptions*
*core_find_mapping() - access to unmaped address, attach a default map to
handle this - addr=0xc131000 nr_bytes=0x4 processor=0x7bfe000 cia=0x16dc*
If I type "bt" in the command line, it returns "Target is executing.".
Does anybody know what can be done?
Thanks.
On Sat, Apr 27, 2013 at 9:22 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
>  You would have had to explicitly install or build gdb. PowerPC gdb is supported and uses the psim bsp.
> "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
>  Hi all,
>  I have built RTEMS from source for PowerPC a while ago, but I have just
> realized there is no powerpc-rtems4.11-gdb file, thus not allowing me to
> test my .exe.
>  Is that correct? Have I built it wrongly? Is there another way to test
> it?
>  Thanks.
> Cassio
URL: <http://lists.rtems.org/pipermail/users/attachments/20130427/66122b3e/attachment.html>
