No GDB file
Sun Apr 28 03:20:46 UTC 2013
Try powerpc-rtems4.11-run filename.exe
Or check out rtems-testing.git and use the sim-scripts/psim
path/to/filename.exe
On Apr 27, 2013 10:12 PM, "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
> Ok. Installed it.
> When I try to run my .exe (and an example one) it returns the following:
> *rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC cannot
> initialize exceptions*
> *core_find_mapping() - access to unmaped address, attach a default map to
> handle this - addr=0xc131000 nr_bytes=0x4 processor=0x7bfe000 cia=0x16dc*
> If I type "bt" in the command line, it returns "Target is executing.".
> Does anybody know what can be done?
> Thanks.
> On Sat, Apr 27, 2013 at 9:22 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
>>  You would have had to explicitly install or build gdb. PowerPC gdb is supported and uses the psim bsp.
>>  Hi all,
>>  I have built RTEMS from source for PowerPC a while ago, but I have just
>> realized there is no powerpc-rtems4.11-gdb file, thus not allowing me to
>> test my .exe.
>>  Is that correct? Have I built it wrongly? Is there another way to test
>> it?
>>  Thanks.
>> Cassio
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20130427/94aac6a2/attachment.html>
