No GDB file
Joel Sherrill
Joel.Sherrill at OARcorp.com
Sun Apr 28 13:27:13 UTC 2013
Invoking the PowerPC simulator to run the psim bsp requires a complicated invocation with a device tree file. Trying to remember all the nuances of invoking each simulator is why rtems-testing/sim-scripts exists.
Clone the repo. Type make and you will get psim and psim-gsb scripts which should work
Gedare Bloom <gedare at rtems.org> wrote:
Try powerpc-rtems4.11-run filename.exe
Or check out rtems-testing.git and use the sim-scripts/psim path/to/filename.exe
On Apr 27, 2013 10:12 PM, "Binkowski, Cassio" <cassioiks at gmail.com<mailto:cassioiks at gmail.com>> wrote:
Ok. Installed it.
When I try to run my .exe (and an example one) it returns the following:
rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC cannot initialize exceptions
core_find_mapping() - access to unmaped address, attach a default map to handle this - addr=0xc131000 nr_bytes=0x4 processor=0x7bfe000 cia=0x16dc
If I type "bt" in the command line, it returns "Target is executing.".
Does anybody know what can be done?
Thanks.
On Sat, Apr 27, 2013 at 9:22 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com<mailto:Joel.Sherrill at oarcorp.com>> wrote:
You would have had to explicitly install or build gdb. PowerPC gdb is supported and uses the psim bsp.
Hi all,
I have built RTEMS from source for PowerPC a while ago, but I have just realized there is no powerpc-rtems4.11-gdb file, thus not allowing me to test my .exe.
Is that correct? Have I built it wrongly? Is there another way to test it?
Thanks.
Cassio
rtems-users mailing list
rtems-users at rtems.org<mailto:rtems-users at rtems.org>
http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20130428/41c2c124/attachment.html>
