_Internal_error_Occurred() in _Thread_Handler()
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Apr 2 14:52:29 UTC 2013
On 4/2/2013 9:45 AM, Matthew J Fletcher wrote:
> Hi
> After some debugging i've found that in some cases a task that calls
> rtems_task_wake_after() will cause the _Thread_Handler to think its
> returned. Has anyone observed this before ?
> A simple case as shown bellow does NOT fail, but a more complex
> example with 30+ tasks, 40+ timers etc does seem to reproducibly fail.
I hope it reliably does this since this failure is by design. :)
> ----------- snip ------------
> rtems_task test_wake_after(rtems_task_argument ignored)
> rtems_task_wake_after(10);
Add "rtems_task_delete( RTEMS_SELF);"
At this point, "test_wake_after()" returns and that is considered
a fatal error in the Classic API.
With a quick look through the manual, I don't see a reference to this
though. Any suggestions on where you would have looked to find this
information?
Or where it should be -- even if it has to be repeated.
> rtems_task Init( rtems_task_argument ignored )
> rtems_status_code status;
> rtems_id id;
> status = rtems_task_create( "wake_after",
> 23,
> 1024,
> RTEMS_DEFAULT_MODES,
> RTEMS_FLOATING_POINT | RTEMS_DEFAULT_ATTRIBUTES,
> &id
> status = rtems_task_start(id, test_wake_after, NULL);
> for (;;)
> On 28 March 2013 15:28, Matthew J Fletcher <amimjf at gmail.com
> <mailto:amimjf at gmail.com>> wrote:
> Thanks all for the suggestions.
> Looking at the 'executing' structure in _Thread_Handler() i can
> see that the last task being executed was the
> rtems_bdbuf_swapout_task(), i dont see how this can return, the
> only chance out of this seems to be via
> rtems_fatal_error_occured() which in the rtl22xx_t BSP is
> implemented as..
> void rtems_fatal_error_occurred(
> uint32_t the_error
> ) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE; Thats just defined as
> __attribute__ ((noreturn));
> The return argument is 0x814c9c50, return code 6 according to the
> 'executing' structure.
> If i comment out the rtems_io_register_driver() /
> rtems_rfs_format() on the NV device the problem does not occur, i
> just switch between the idle task and one of my threads.
> So it looks like rtems_bdbuf_swapout_task() is returning, can i
> help any more tracking things down ?
> On 28 March 2013 14:03, Joel Sherrill <Joel.Sherrill at oarcorp.com
> <mailto:Joel.Sherrill at oarcorp.com>> wrote:
> Just to directly answer the question about the idle thread. It
> is perfectly normal to have a system where that is the only
> ready thread. Even ticker spends most of its execution time in
> this state.
> POSIX threads implicitly delete themselves when they return.
> It is a fatal error for Classic API tasks to do so.
> This is just one example of the differing philosophies behind
> the two APIs.
> --joel
> Sebastian Huber <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 03/28/2013 01:26 PM, Matthew J Fletcher wrote:
> > Hi,
> > I am getting the above and presume i've made a mistake in
> some part of my setup.
> > I know task switching works, i switch between the idle task
> and my Init() task
> > fine, this error seems to occur in the task switch that
> occurs after i
> > rtems_task_suspend() the Init() task. That in itself i guess
> is fine, most of
> > the examples do it.
> > Would the above happen if there were no ready to be
> scheduled tasks except the
> > idle task ?
> The only internal error in _Thread_Handler() is
> INTERNAL_ERROR_THREAD_EXITTED.
> The classic API tasks must not return. You have to delete
> them, e.g. with
> rtems_task_delete(RTEMS_SELF);
> Phone : +49 89 189 47 41-16 <tel:%2B49%2089%20189%2047%2041-16>
> Fax : +49 89 189 47 41-09 <tel:%2B49%2089%20189%2047%2041-09>
> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
> des EHUG.
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> regards
> Matthew J Fletcher
> regards
> Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130402/f88e1f16/attachment-0001.html>
