_Internal_error_Occurred() in _Thread_Handler()
Matthew J Fletcher
amimjf at gmail.com
Tue Apr 2 15:31:31 UTC 2013
Hi,
Ok, so i enclosed the child thread call to rtems_task_wait_after() in a
never ending for loop expecting no error to be thrown (as the thread never
returns) and i still end up in _Internal_error_Occured from _Thread_Handler.
This is all in 4.10.2. I've run the following several times now, same
result, i dont see how the rtems_task_wake_after() is breaking out of the
for(;;) to return. But looking at the executing->Start->entry_point in
_Thread_Handler test_wake_after() was the last task run.
-------------- snip -------------
rtems_task test_wake_after(rtems_task_argument ignored)
for(;;)
rtems_task_wake_after(10);
/* application code happening on interval here */
rtems_task Init( rtems_task_argument ignored )
rtems_status_code status;
rtems_id id;
status = rtems_task_create( "wake_after",
23,
1024,
RTEMS_DEFAULT_MODES,
RTEMS_FLOATING_POINT | RTEMS_DEFAULT_ATTRIBUTES,
&id
status = rtems_task_start(id, test_wake_after, NULL);
rtems_task_delete(RTEMS_SELF);
On 2 April 2013 15:52, Sebastian Huber
<sebastian.huber at embedded-brains.de>wrote:
> On 04/02/2013 04:45 PM, Matthew J Fletcher wrote:
>> rtems_task test_wake_after(rtems_task_**argument ignored)
> This will result in an internal error once the rtems_task_wake_after()
> returns. You can use this:
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130402/cf2044d2/attachment-0001.html>
