Error in creating timer
Joel Sherrill
joel.sherrill at OARcorp.com
Sun Apr 7 22:18:52 UTC 2013
On 04/07/2013 03:32 PM, manish jain wrote:
> Thanks Joel..
> It is working now but while I used clock driver with timer I didn't
> get any compiler error..
I am glad to know that worked.
I have a patch in my tree so next time someone will get a compile error.
You can only specify one of need clock, need timer, or do not need clock.
There were checks for having 0 defined but not > 1.
--joel
> Manish
> On Sun, Apr 7, 2013 at 4:18 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
> On 04/07/2013 03:05 PM, manish jain wrote:
> Hi,
> I am just running a small Init task in which I am creating a
> "timer". But the status returned by the "rtems_timer_create"
> function is "RTEMS_TOO_MANY ". I think, this status is
> referring to a maximum numbers of objects already allocated.
> But in my task I am just creating one timer. Do I need to
> preconfigure before using the timer? For now I am using
> following macros:
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
> #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
> Can someone tell me what I might be missing? I am currently
> running my task on sparc sis simulator.
> You can't configure the timer and clock driver at the same time.
> This should have resulted in a compile time error. On most BSPs,
> these use the same hardware so it is considered a general error.
> Besides, the timer driver is for a "benchmark timer" used by
> the RTEMS Timing Test Suites -- and they assume no clock tick.
> I don't know why your initialization task needs floating point but
> that is your application's requirement.
> If you are creating a Classic API timer via the rtems_timer_create()
> method, then you need to configure the system to account for
> how many instances of Classic API Timers you need. Something
> like this:
> #define CONFIGURE_MAXIMUM_TIMERS 1
> If you need more than one timer, then up that number.
> If you want standard in, out and error to work (e.g. printf()), then
> you should also have:
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> I just posted a re-write of the Configuring a System chapter in the
> Users Guide. Everything you should need to know is in it and
> hopefully better presented than the current version.
> http://www.rtems.org/ftp/pub/rtems/people/joel/config-v1.pdf.bz2
> The current version is terse where the new version includes
> more information in a more structured fashion. :)
> Manish
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35806
> Support Available (256) 722-9985 <tel:%28256%29%20722-9985>
URL: <http://lists.rtems.org/pipermail/users/attachments/20130407/8204a424/attachment-0001.html>
