build stuck: rtems-4.10.2, arm-elf, nds
Ralf Corsepius
ralf.corsepius at rtems.org
Wed Apr 10 06:20:22 UTC 2013
On 04/10/2013 04:18 AM, Matt Wette wrote:
> I'm looking for hints.
> I built tools, then configure rtems-4.10.2 for --target=arm-elf, then make RTEMS_BSP=nds
Why are you trying this?
* "arm-elf" is not a valid target tuple for RTEMS
* "arm-elf" built-GCC toolchains are addressing an entirely different
systems (Usually OS-less, bare-metal targets).
You need to use an "arm-rtems4.10" built-toolchain.
Ralf
