Delay setting RTEMS clock with TOD_Set.
Rafael Morales
rmorales at iaa.es
Wed Apr 10 17:47:32 UTC 2013
Thank you for your responses.
I will play with different "CONFIGURE_MICROSECONDS_PER_TICK" values
configuring "CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER" and
setting the clock.
I expect to find the right values.
Best regards.
> On 4/10/2013 8:21 AM, Gedare Bloom wrote:
>> You can control the tick resolution with the configuration option:
>> #define CONFIGURE_MICROSECONDS_PER_TICK 1000
>> Or some suitable number other than 1000. (The default is 10000.)
>> This option affects the granularity of timing and scheduling events.
> Your examples did not use any public APIs. What did you use to set the
> clock?
> If rtems_clock_set(), then it is specified at a tick granularity. The
> POSIX
> clock_settime() and clock_gettime() use struct timespec to specify the
> time.
> Some commonly used POSIX time related methods are enabled even when
> --disable-posix is specified.
> If this is simply rounding based on the CONFIGURE_MICROSECONDS_PER_TICK,
> then you can configure with
> and run various values through setting and getting the clock.
> The disable/enable dispatch will only have impact if there is a task
> readied as a side-effect of changing the time. And this leads to
> preemption of the currently executing task.
> --joel
>> -Gedare
>> On Wed, Apr 10, 2013 at 9:16 AM, Gedare Bloom <gedare at rtems.org> wrote:
>>> I guess this is in the rtems_clock_set routine that the TOD_Set is
>>> called? [1]
>>> My best guess is that the granularity of the time is quite coarse, so
>>> you are seeing some rounding errors based on when in the current
>>> "tick" the TOD_Set is called. For example, look at lines 51-53:
>>> newtime.tv_sec = _TOD_To_seconds( time_buffer );
>>> newtime.tv_nsec = time_buffer->ticks *
>>> rtems_configuration_get_nanoseconds_per_tick();
>>> The fine-grained resolution of time (nanoseconds) is approximated by
>>> the number of ticks times the configured ns per tick. By default this
>>> is going to be about 10 milliseconds per tick, so you would expect on
>>> average about 5 ms difference between the actual time and the
>>> approximated time.
>>> [1]
>>> http://git.rtems.org/rtems/tree/cpukit/rtems/src/clockset.c?id=4.10.2
>>> -Gedare
>>> On Wed, Apr 10, 2013 at 6:00 AM, Rafael Morales <rmorales at iaa.es>
>>> wrote:
>>>> Dear all,
>>>> We are using a development system based on Leon3 at 25MHz clock and
>>>> RTEMS
>>>> 4.10 (Gaisler version 4.10.1.2.8).
>>>> We are experiencing a big delay setting the clock time with TOD. The
>>>> sequence is:
>>>> struct timespec startTimeStamp;
>>>> get_time_stamp(&startTimeStamp);
>>>> _Thread_Disable_dispatch();
>>>> _TOD_Set( newtime );
>>>> _Thread_Enable_dispatch();
>>>> struct timespec stopTimeStamp;
>>>> get_time_stamp(&stopTimeStamp);
>>>> If we get the new time after the _TOD_Set, we see that current time
>>>> as about
>>>> 1-5 milliseconds late. We have try to delete the
>>>> and _Thread_Enable_dispatch with no results. It seems that the call
>>>> _TOD_Set
>>>> is the responsible of the delay
>>>> Any idea about how to manage this situation?
>>>> Thanks in advance.
>>>>> Hi,
>>>>> here is the proof for the patched hello world on the sis target
>>>>> and the
>>>>> patch generated by git. I hope it's okay.
>>>>> I also got a first draft of the proposal, so the question is: Who
>>>>> wants to
>>>>> read it?
>>>>> Regards,
>>>>> Philipp
>>>>> screenshot:
>>>>> https://wwwpub.zih.tu-dresden.de/~s8940405/gdb_hello_world.png
>>>>> patch:
>>>>> https://wwwpub.zih.tu-dresden.de/~s8940405/0001-hello-world-gsoc-2013-fix.patch
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.org
>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
