Debugging basic BSP tasking functionality
Wed Apr 17 15:01:29 UTC 2013
On 4/17/2013 9:47 AM, Matthew J Fletcher wrote:
> >If you put an explicit call to rtems_stack_checker_is_blown() in
> Init() at
> >various points, does it think things are OK?
> I put in a few and even the last one before the Init() task deletes
> itself is ok.
OK.
> >Just to be clear.. is this with the rtl22xx or rtl22xx_t BSP? The
> non-thumb version
> >uses -mapcs-frame which no other BSP uses. That makes me wonder.
> rtl22xx_t 'Thumb', -mapcs-frame is passed on the gcc command line.
If this is the BSP you are using, take it off and try again. This is the
only BSP
using this option. Sebastian can probably comment on the other arguments.
> >Not with RTEMS. When you enter/exit an ISR, you go through some
> >code which saves the proper registers, probably switches you to
> >a dedicated stack, and does the OS stuff needed so it will do
> >any needed dispatching at the end of the interrupt.
> Is this shared between BSPs ? i tried to look for this and failed.
It is absolutely shared. The BSP has to provide some glue code but
between libbsp/shared, libbsp/<ARCH>/shared, and the appropriate
libcpu directory, you will find the code.
Look for shared and libcpu in the Makefile.am.
Now as Sebastian says, the handler might be mis-registered as raw
not OS interrupt. And the BSP may have been mechanically converted
to the new shared PIC interrupt code used by many BSPs but not
tested.
> On 17 April 2013 15:34, Joel Sherrill <joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>> wrote:
>     On 4/17/2013 9:04 AM, Matthew J Fletcher wrote:
>>     Hi,
>>     Yes it the stack pointer out of range, because the current stack
>>     pointer returned by GCC _builtin_frame_XX in the IDLE thread
>>     looks like its actually that from the Init() thread.
>     You are completely in C code when this happens. There has been
>     assembly
>     to switch to the task initially (e.g. into _Thread_Handler) and if
>     an interrupt
>     occurred.
>     Init() at
>     It is easy for the stack not to be initialized to match gcc or
>     gdb's expectation
>     of how it ends.
>     non-thumb version
>>     Thinking this through,my target is Thumb, so the C interrupt
>>     handler should be in a arm file with -mthumb-interwork set on the
>>     compile line.
>>     I guess GCC can not auto-magicly know what particular functions
>>     are interrupts, so should there be some entry/exit functions to
>>     save/restore the stack, etc, like these...
>>     http://www.procyonengineering.com/embedded/arm/armlib/docs/html/group__processor__lpc2000.html
>>     ISR_ENTRY / ISR_EXIT
>     --joel
>>     On 17 April 2013 13:40, Sebastian Huber
>>     <sebastian.huber at embedded-brains.de
>>     <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>         On 04/17/2013 02:27 PM, Matthew J Fletcher wrote:
>>              >Here a context switch from the Init to the idle (I
>>             guess) thread happens.
>>               The >_User_extensions_Thread_switch
>>              >() is called before the context switch and the running
>>             thread is checked.  So
>>             a sp of >0x814d299c must be in the range of the Init
>>             stack area.
>>             Yes it is, Init() stack area is 0x814d1a70 -> 0x814d2a74
>>             (4100 bytes). So it
>>             looks like the stack pointer is not getting adjusted
>>             correctly when task
>>             switching into a new thread ? as the rtems_idle task is
>>             using the Init() stack
>>             pointer.
>>         Now I am a bit confused.  What check goes wrong in
>>         Stack_check_Frame_pointer_in_range() at check.c:69 0x81180f6e
>>         rtems_stack_checker_switch_extension() at check.c:276 0x81180f6e
>>         _User_extensions_Thread_switch() at userextthreadswitch.c:41
>>         0x8118cbaa
>>         _Thread_Dispatch() at threaddispatch.c:128 0x8118bce6
>>         _Thread_Enable_dispatch() at threaddispatch.c:59 0x8118bd5e
>>         rtems_task_delete() at taskdelete.c:94 0x81189750
>>         Init() at startup.c:241 0x81007840
>>         In case the stack pointer is out of range, then I guess that
>>         the interrupt exception processing is broken.  It is hard to
>>         know what happens without an actual target.
>>              > nm your-app.exe | grep 'bsp_\(section\|stack\)' | sort
>>             No matches.
>>         Ok, 4.10 uses the old linker command files.  These symbols
>>         are only available in 4.11.
>>         Sebastian Huber, embedded brains GmbH
>>         Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>         Phone   : +49 89 189 47 41-16 <tel:%2B49%2089%20189%2047%2041-16>
>>         Fax     : +49 89 189 47 41-09 <tel:%2B49%2089%20189%2047%2041-09>
>>         E-Mail  : sebastian.huber at embedded-brains.de
>>         PGP     : Public key available on request.
>>         Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>>         des EHUG.
>>     regards
>>     Matthew J Fletcher
>     Joel Sherrill, Ph.D.             Director of Research & Development
>     joel.sherrill at OARcorp.com  <mailto:joel.sherrill at OARcorp.com>         On-Line Applications Research
>     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>     Support Available                (256) 722-9985
> regards
> Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130417/91d3dbb0/attachment-0001.html>
