Effect of additionnal save/restore instructions
Cláudio Silva claudiodcsilva at gmail.com
Tue Apr 23 09:27:20 UTC 2013
Hello Leonard,
I would add a volatile after the __asm__ otherwize gcc can optimize away
some of your code.
The windows underflow and overflow traps will occur during normal
execution. It is expected behavior when you do a restore and the previous
register window is invalid (marked as 1 in the $wim register).
Regarding your code, without the save and restore instruction you are
changing the current window %l7 register and gcc might be not expecting it.
To solve this you will need to clobber the register as Chris described in
the previous email.
The save and restore instruction are not a good addition to that code,
because they may trigger an underflow/overflow trap therefore increasing
the execution time of that function.
The random behavior you are seeing might be due to stack corruption
originating from the %sp register of the new window (after the save) being
set to an old value (from an older register window). "save" should be "save
%sp, -96 (?), %sp". Nevertheless this is just my quick guess ;)
Regards,
Cláudio
On Tue, Apr 23, 2013 at 10:02 AM, Leonard Bise <leonard.bise at syderal.ch>wrote:
> Hello all,
> I'm having a problem regarding the processor window registers that I
> cannot explain easily mostly because I'm not super familiar with this
> subject.
> First, I'm using a LEON2 Sparc v8 processor and RTEMS 4.8 version which is
> required by our project.
> We have a function using inline assembly to perform a flat delay, here is
> the code it use.
> void SCET_wait_2us(void) {
>         /*#[ operation SCET_wait_2us() */
>         /* Performs a 60us delay using an ASM loop, this piece of code has
> been
>          * measured on HW to validate the duration is correct */
>         __asm__("                                \
>                 save;                            \
>                 set " XSTR(NB_ITER_60US) ", %l7; \
>                 StartLoop1us:                    \
>                 dec 1, %l7;                      \
>                 cmp %l7, 0;                      \
>                 bne StartLoop1us;                \
>                 nop;                             \
>                 restore;                         \
> Originally this code didn't have the save and restore instruction but our
> sub contractor added them because they had problems compiling. I find it an
> odd solution but whatever.
> Once this code was implemented we started seeing random processor
> reset occurring in various contexts.
> I tested this code while being in the Eclipse debugger and once the crash
> happened I noticed I had a segmentation fault in Eclipse. I used GRMON to
> check the processor register and noticed that the last trap that occurred
> was a window underflow trap 0x06.
> I found in the RTEMS sources the code for this handler, and while I
> haven't understood everything I took out that the code was trying to
> recover from this error, is this correct?
> I copied the trap handler code below.
> RTEMS 4.8 branch
> file : rtems / c / src / lib / libcpu / sparc / reg_win / window.S
> SYM(window_underflow_trap_handler):
>          * Calculate new WIM by "rotating" the valid bits in the WIM left
>          * by one position. The following shows how the bits move for a
> SPARC
>          * cpu implementation where SPARC_NUMBER_OF_REGISTER_WINDOWS is 8.
>          * OLD WIM = 76543210
>          * NEW WIM = 07654321
>          * NOTE: New WIM must be stored in a global register since the
>          * "save" instruction just prior to the load of the wim
>          * register will result in the local register set changing.
>         mov %wim, %l3 ! Calculate new WIM
>         sll %l3, 1, %l4 ! l4 = WIM << 1
>         srl %l3, SPARC_NUMBER_OF_REGISTER_WINDOWS-1, %l5
>                                         ! l5 = WIM >> (Number Windows-1)
>         or %l5, %l4, %l5 ! l5 = (WIM << 1) |
>                                         ! (WIM >> (Number Windows-1))
>         mov %l5, %wim ! load the new WIM
>         nop; nop; nop
>         restore ! Two restores to get into the
>         restore ! window to restore
>         ldd [%sp + 0x00], %l0 ! First the local register set
>         ldd [%sp + 0x08], %l2
>         ldd [%sp + 0x10], %l4
>         ldd [%sp + 0x18], %l6
>         ldd [%sp + 0x20], %i0 ! Then the input registers
>         ldd [%sp + 0x28], %i2
>         ldd [%sp + 0x30], %i4
>         ldd [%sp + 0x38], %i6
>         save ! Get back to the trap window.
>         save
>         jmp %l1 ! Re-execute restore.
>         rett %l2
> From my understanding this code should not ever fail, is that correct?
> What I'm not sure is that if this type of trap can be a
> common occurrence or if that means something went bad in the software.
> Basically now I removed the save/restore and it seems to be working fine
> but I'll have to explain exactly what was happening before.
> Is the compiler not expecting the user to add save/restore and could that
> lead to the behavior we see sometimes (processor reset). What are the usual
> way to handle this type of inline assembly? Never use save/restore?
> Also our customer gave us a sequence of command to send to the software
> that would produce this reset systematically however when we got the
> equipment over here, I tried with the same code the sequence and it is not
> happening as often as they say. There seem to be a lot of randomness to
> this problem.
> I really hope someone can provide some knowledge on this type of issue.
> *Léonard Bise*
> Software Design Engineer
> Direct Line +41 (0)32 338 9902
> *SYDERAL SA*
> Neuenburgstrasse 7
> CH-3238 Gals (Switzerland)
> Desk Line +41 (0)32 338 9800
> Web Site http://www.syderal.ch
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20130423/e515dc83/attachment-0001.html>
