Unaligned problem when porting rtems for arm
Wed Apr 24 13:43:25 UTC 2013
On 04/24/2013 03:32 PM, Peng Fan wrote:
> The compiler options in make/custom/*.cfg file is:
> CPU_CFLAGS = -mstructure-size-boundary=32 -mcpu=arm1176jzf-s -mfpu=vfp
> -float-abi=soft -DCPU_S3C6410
> # optimize flag: typically -O2
> CFLAGS_OPTIMIZE_V = -O2 -g
> I will try older gcc versions or remove the -O2 option.
Which GCC version do you use?
Are you sure that you have a ARM1176JZF core?  This core has support for
unaligned data access.  Is this enabled and supported in your hardware?
In case you use (hopefully) the EABI based tool chain, then remove the
-mstructure-size-boundary=32 and -mfpu=vfp.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
