printf vs. printk (on LPC32XX)
Sebastian Huber
Mon Apr 29 10:40:46 UTC 2013
On 04/29/2013 11:10 AM, SAeeD wrote:
> Hello everyone,
> I'm getting some weird problems when running tmtests on PhyCORE LPC3250.
> I've configured rtems4.10.2 as follows:
> $ mkdir b-lpc3250-phycore
> $ cd b-lpc3250-phycore
> $ ../configure --target=arm-rtems4.10
> --enable-rtemsbsp=lpc32xx_phycore --enable-tests=yes
> --enable-networking --enable-posix --prefix=$PWD/bsp-install
> $ make all install
> When I run tmtests, specifically talking, tm01 on PhyCORE LPC3250,
> everything works smoothly and all texts are printed on the console.
> But when I run, tm03, it hangs in the middle of printing jobs.
> When I changed the definition of put_time in timesys.h to use printk
> instead of printf, tmtests are working without any problem. That is,
> those lines that were printed incompletely when using printf, are now
> printed completely using printk.
> I must mention that everything works fine with rtems4.11. (Without any
> modification.)
> I want to ask: what's the point indeed?
The difference between 4.10.2 and 4.11 is this in configure.ac:
+RTEMS_BSPOPTS_SET([TESTS_USE_PRINTK],[*],[1])
+RTEMS_BSPOPTS_HELP([TESTS_USE_PRINTK],[tests use printk() for output])
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
