SDHC driver of RTEMS
Mozzhuhin Andrey
amozzhuhin at ec-continuum.ru
Mon Aug 5 12:51:12 UTC 2013
On 03.08.2013 05:41, 芮正新 wrote:
> Hi all,
> I want to use SDHC SD card on my MPC8309SOM board.
> RTEMS not include the SDHC driver, so I try to port the SDHC driver from u-boot code, but it seem to have too many problems.
> When I set CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS >1, the driver can't work well.
> The BRDA task looks like be blocked after read the number of CONFIGURE_BDBUF_BUFFER_MAX_SIZE blocks, and some seconds later, the fread function return error.
> The fwrite function often failed.
> I searched the web and know that P1020 also has SDHC,
> http://www.rtems.com/wiki/index.php/QorIQ.
> Anyone can give me some help for the SDHC driver? Very thanks to you.
> rtems-users mailing list
> rtems-users at rtems.org
Hi, I had played with SDHC with AT91RM9200 some time ago.
I port (see attachment) mixed source code from Linux and U-Boot and it
works very well with RTEMS FAT filesystem.
To use this code you need implement device support structure mmc_device
and replace mci_mmc_device with it.
Unfortunately this code is under GPLv2 and can't be included in RTEMS.
If someone need help for native MMC stack implementation for RTEMS I can
spend some time.
Type: application/zip
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20130805/b9af7032/attachment.zip>
