Issues with compiling RTEMS 4.10.2 with Gaisler drivers 1.2.11 on Ubuntu 13.04
"M.Eng. René Schwarz | German Aerospace Center (DLR)"
rene.schwarz at dlr.de
Thu Aug 8 10:01:46 UTC 2013
Hi,
I am fairly new to RTEMS and want to understand how to build RTEMS
4.10.2 with Gaisler drivers 1.2.11 for SPARC on Ubuntu 13.04 from
source. What I did up to now is:
* I prepared a dedicated user and directory structure for all my RTEMS
work on a clean Ubuntu 13.04 x64 installation. I want all RTEMS-related
files to reside in /home/rtems/rtems_base (no files outside this path).
* autoconf 2.68 and automake 1.11.1 have been compiled and installed.
* Expat 2.1.0 has been compiled and installed, as well as binutils 2.20.1.
* GCC 4.4.7 has been patched witch the patches
4.10/gcc/gcc-core-4.4.7-rtems4.10-20120314.diff
4.10/gcc/gcc-g++-4.4.7-rtems4.10-20120314.diff
from the Git repository git://git.rtems.org/rtems-tools.git and
newlib 1.18.0, patched with
4.10/newlib/newlib-1.18.0-rtems4.10-20110518.diff
has been linked into the GCC sources. Finally, GCC has been compiled
and installed.
* GDB 7.3.1 has been patched with
4.10/gdb/gdb-7.3.1-rtems4.10-20120918.diff
and has been compiled and installed.
If necessary, I can provide you a document with all steps I did since
the clean Ubuntu install.
When I configure RTEMS and run a 'make all' now, I will get the
following error:
configure: error: in
`/home/rtems/rtems_base/build/arch/sparc-rtems4.10/rtems-4.10.2-gaisler-1.2.11/sparc-rtems4.10/c/erc32':
configure: error: C compiler cannot create executables
See `config.log' for more details
'config.log' states the following:
configure:3438: sparc-rtems4.10-gcc -V >&5
sparc-rtems4.10-gcc: '-V' option must have argument
configure:3449: $? = 1
configure:3438: sparc-rtems4.10-gcc -qversion >&5
sparc-rtems4.10-gcc: unrecognized option '-qversion'
sparc-rtems4.10-gcc: no input files
configure:3469: checking whether the C compiler works
configure:3491: sparc-rtems4.10-gcc -mcpu=cypress -O2 -g
conftest.c >&5
/tmp/ccmy1mrr.s: Assembler messages:
/tmp/ccmy1mrr.s:13: Error: unrecognized symbol type ""
/tmp/ccmy1mrr.s:14: Error: unknown pseudo-op: `.proc'
/tmp/ccmy1mrr.s:21: Error: bad register name `%o7+8'
/tmp/ccmy1mrr.s:22: Error: bad register name `%o0'
/tmp/ccmy1mrr.s:28: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:29: Error: unknown pseudo-op: `.uahalf'
/tmp/ccmy1mrr.s:30: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:33: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:35: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:36: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:37: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:38: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:39: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:42: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:45: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:46: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:47: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:109: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:110: Error: unknown pseudo-op: `.uahalf'
/tmp/ccmy1mrr.s:111: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:112: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:113: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:115: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:117: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:118: Error: unknown pseudo-op: `.uahalf'
/tmp/ccmy1mrr.s:119: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:122: Error: unknown pseudo-op: `.uahalf'
/tmp/ccmy1mrr.s:123: Error: unknown pseudo-op: `.uahalf'
/tmp/ccmy1mrr.s:124: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:125: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:126: Error: unknown pseudo-op: `.uaword'
/tmp/ccmy1mrr.s:127: Error: unknown pseudo-op: `.uaword'
configure:3495: $? = 1
configure:3533: result: no
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "rtems-c-src"
| #define PACKAGE_TARNAME "rtems-c-src"
| #define PACKAGE_VERSION "4.10.2"
| #define PACKAGE_STRING "rtems-c-src 4.10.2"
| #define PACKAGE_BUGREPORT "http://www.rtems.org/bugzilla"
| #define PACKAGE_URL ""
| /* end confdefs.h. */
| int
| main ()
| return 0;
configure:3538: error: in
configure:3540: error: C compiler cannot create executables
Now I am stuck, because I have no idea whats the reason for this error
is. It is also unclear for me why 'sparc-rtems4.10-gcc -V' outputs an
error and whether this is expected or not.
So I hope somebody can help me to solve this problem. Thank you in advance.
Kind regards,
René
Sincerely yours,
M.Eng. *René Schwarz*
Member of the Helmholtz-Association
| Institute of Space Systems
| Guidance, Navigation and Control Systems, Avionics (RY-GNC)
Room 2.10 · Robert-Hooke-Str. 7 · DE-28359 Bremen
Phone: +49-(0)421-24420-1165 · Telefax: +49-(0)421-24420-1120
E-Mail: rene.schwarz at dlr.de · Internet: http://www.DLR.de/irs/en/
Type: application/pgp-signature
Desc: OpenPGP digital signature
URL: <http://lists.rtems.org/pipermail/users/attachments/20130808/9f41dd90/attachment.bin>
