Issues with compiling RTEMS 4.10.2 with Gaisler drivers 1.2.11 on Ubuntu 13.04
"M.Eng. René Schwarz | German Aerospace Center (DLR)"
rene.schwarz at dlr.de
Thu Aug 8 14:51:01 UTC 2013
Hi,
thank you all for your help --- both on and off this mailing list. The
problem seems to be solved now with the kind help of Sebastian Huber:
The given '--prefix=...' has to be the same while configuring and
building binutils and gcc.
The error is gone now, but I ran into the situation that I am getting
the following error now after doing a 'make all' for RTEMS:
make[2]: Leaving directory
`/home/rtems/rtems_base/build/arch/sparc-rtems4.10/rtems-4.10.2-gaisler-1.2.11/sparc-rtems4.10/c'
Making all in erc32
make[2]: Entering directory
`/home/rtems/rtems_base/build/arch/sparc-rtems4.10/rtems-4.10.2-gaisler-1.2.11/sparc-rtems4.10/c/erc32'
make[2]: *** No rule to make target `all'. Stop.
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
make: *** [all-recursive] Error 1
After checking
'/home/rtems/rtems_base/build/arch/sparc-rtems4.10/rtems-4.10.2-gaisler-1.2.11/sparc-rtems4.10/c/erc32'
it turned out that there is no Makefile at all in this folder. Do you
have an additional hint for me?
Sincerely yours,
M.Eng. *René Schwarz*
Member of the Helmholtz-Association
| Institute of Space Systems
| Guidance, Navigation and Control Systems, Avionics (RY-GNC)
Room 2.10 · Robert-Hooke-Str. 7 · DE-28359 Bremen
Phone: +49-(0)421-24420-1165 · Telefax: +49-(0)421-24420-1120
E-Mail: rene.schwarz at dlr.de · Internet: http://www.DLR.de/irs/en/
Type: application/pgp-signature
Desc: OpenPGP digital signature
URL: <http://lists.rtems.org/pipermail/users/attachments/20130808/ad522757/attachment.bin>
