Issues with compiling RTEMS 4.10.2 with Gaisler drivers 1.2.11 on Ubuntu 13.04
"M.Eng. René Schwarz | German Aerospace Center (DLR)"
rene.schwarz at dlr.de
Fri Aug 9 08:20:48 UTC 2013
On 09.08.2013 08:35, Mick Davis wrote:
> If you've had tool chain issues it might be best to try again after a
> ./bootstrap -c
> ./bootstrap
After solving the GCC/Binutils issues, I completely re-initialized my
directory structure, deleting all files in ~/rtems_base and starting
from scratch again. So I thought this might not be the reason for the
actual compiling problem.
I tried it now again using './bootstrap -c' and a subsequent
'./bootstrap' with a clean source tree from
<http://gaisler.com/anonftp/rcc/src/rtems-4.10-1.2.11-src.tar.bz2>
and it works now. Before it did exactly the same, but without a prior
'./bootstrap -c'. As far as I can see this step is not documented
somewhere in the Gaisler docs and it might be a bug within the source
package.
Thank you both Mick and Chris very much! I would never have thought of
that without your help.
Kind regards,
René
Sincerely yours,
M.Eng. *René Schwarz*
Member of the Helmholtz-Association
| Institute of Space Systems
| Guidance, Navigation and Control Systems, Avionics (RY-GNC)
Room 2.10 · Robert-Hooke-Str. 7 · DE-28359 Bremen
Phone: +49-(0)421-24420-1165 · Telefax: +49-(0)421-24420-1120
E-Mail: rene.schwarz at dlr.de · Internet: http://www.DLR.de/irs/en/
Type: application/pgp-signature
Desc: OpenPGP digital signature
URL: <http://lists.rtems.org/pipermail/users/attachments/20130809/890beb95/attachment.bin>
