Re: MinGW
williamssimonp at gmail.com
Fri Aug 9 11:24:14 UTC 2013
I tried the plug-in, but couldn’t get it to recognise the compiler. I only had about an hour to play with it though. I am planning to do a bit more research over the weekend. I got the standard CDT to recognise the compiler with no problem and so that and a bunch of manually added includes, libraries and other compiler and linker options are my fall back. I am using Kepler and I don’t know that the plug-in is compatible.
Sent from Windows Mail
Sent: Friday, 9 August 2013 10:41
To: rtems-users at rtems.org
On 2013-08-09 10:08, williamssimonp at gmail.com wrote:
> I am trying to get RKI to build, but this is early days. I eventually need to
> use C++ and I like to use the Eclipse IDE and so I have imported the source
> into Eclipse with a view to getting the original C code to work, prior
> to porting it to C++ as a base for my project. I am getting undefined
> references in the link, but I can sort this out, I just need to find which
> libraries are missing.
There is an Eclipse plug-in for RTEMS:
http://wiki.rtems.org/wiki/index.php/RTEMS_Eclipse_Plug-in
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20130809/2655fc32/attachment.html>
